CaptainCaveMann
macrumors 68000
1,518
This is weird. I use a pc at the rents house and when i go to delete my junk mail in my hotmail box it works fine. But when im using my ibook and i try and delete my junk mail in my hotmail box it wont delete it! Its driving me crazy. Anyone know why its doing this? Thanks
PlaceofDis
macrumors Core
Jan 6, 2004
19,241
6
what browser are you using? have you tried logging off of hotmail and then back in to see if there is a change (could be the cache)
are you useing the Mail Hotmail plugin? that could be causing the problem as well
ps why are you using hotmail when Gmail is out there? (just curious)
CaptainCaveMann
macrumors 68000
1,518
Gmail is my main mail address thank you very much. Haha i still have some stuff coming to my hotmail address. Im using Safari to check my hotmail.
:confused:
PlaceofDis
macrumors Core
Jan 6, 2004
19,241
6
haha im just playing around with you, didnt mean to sound harsh or anything.
have you tried logging out of your hotmail account after emptying the trash and then back in?
also go to the safai drop down menu and empty your cache, that might help
CaptainCaveMann
macrumors 68000
1,518
Ok heres an update. I just used internet explorer on my ibook to check the hotmail box. I got like two pop ups saying that the info i was about to send was not secure and could be viewed by ouside people. Whats the deal with that? I was just logging into my hotmail account. Anyway, i tried deleting the junk mail using internet explorer and it worked. Im gonna try again with safari doing the things you suggested right now.
CaptainCaveMann
macrumors 68000
1,518
Ok tried both of your suggestions with no luck. I still cant delete my junk mail using Safari. Weiiiirrrdd. :confused:
Dalriada
Aug 26, 2004
277
Moorlough Shore
Note also that you can use yr Gmail accnt for MSN Messenger if you hve many PC buddies with accounts. Just register your Gmail accnt with Passport.net and bingo...
- Dal
PlaceofDis
macrumors Core
Jan 6, 2004
19,241
6
i wouldnt go so far as to reset safari, someone else may know why this is causing an issue. do you have the debug menu visible in safari? from there you could try and spoof Hotmail into thinking that you are IE to see if it just doesnt like Safari i suppose....but i really dont know where to go from here, sorry
Mav451
macrumors 68000
Jul 1, 2003
1,657
Maryland
Hotmail stuff is in Javascript...I believe you need to see this pop-up window (for your Junk Mail) asking you to check the box "Report these as Junk Mail" or something along those lines.
pulsewidth947
macrumors 65816
Jan 25, 2005
1,106
2
Your not the only one..
I get the same problem if I open my junk folder and try to empty from there. I get the JS popup, but it doesnt delete.
The way round it is to go onto the first page (from messenger or something) where you get the following page -
inbox 1msg
trash 0msg
junk 2msg empty
if that makes sense.. then click the empty button there and that seems to work.
but yeah use another browser if it annoys you too much.
vouder17
Apr 30, 2003
828
4
Home
Yeah me too, i also have the same problem....fooking junk mail from all the enlargement and sex companies that exist...It drives me crazy. What i do is just delete it from IE. Safari doesnt work.....safari has been letting me down latly :( :(
mad jew
Moderator emeritus
Apr 3, 2004
32,191
9
Adelaide, Australia
Safari was working like poo for me when we got the 10.3.9 update. It'd do all sorts of random stuff but since I reset it, it's been playing nicely again. :)
It might be worth a try after all.
CaptainCaveMann
macrumors 68000
1,518
- Dal
Can you explain this more? Id like to try it out.
PlaceofDis
macrumors Core
Jan 6, 2004
19,241
6
all you have to do is register at .net with your gmail account to use it with msn messenger. simple as that, pointless for me because i use aim....but i know many people do not though
CaptainCaveMann
macrumors 68000
1,518
inbox 1msg
trash 0msg
junk 2msg empty
Ok i tried your suggestion and it totally worked. Thanks. I get the same JS pop up when i try to delete from the actual mailbox but still it wont delete. This is sooo annoying. They need to get a fix for this. Hotmail is extremely popular. Although i use Gmail as my main account id still like to have my hotmail account working properly from Safari.
janiquoi
May 19, 2005
Help with MSN
I'm running OS 10.2.8 and have downloaded MSN Messenger 4.0.1 but I can't use it! When I open the application it signs me in as being offline and then the application freezes up (the rotating beachball appears) and I have to force quit the application. Any suggestions?!?!?!?!?!?! :confused:
