mizelly41
153
7
Illinois
I have Parallels installed on my Macbook with Windows XP. The problem I have is that when I have a Windows program opened, the icon in the dock for that program is blank.
I thought that I had the most up-to-date version when I did not. I updated and the icons are back.
instructions are in my thread. but here are some better ones.
open your Documents folder and then open the Parallels folder. inside there should be a folder called "Windows XP" or something similar. open that and then open the Windows Applications folder. look for Internet Explorer and right click on it and choose "Show Package Contents". open the Contents folder and then the Resources folder and the icon should be there. its called "WinAppHelper.icns". zip the icon and attach it to your next post. thanks!
