L
Lau
Guest
I recently got a Netgear WGR614 wireless router to replace my old Netgear ASDL router, as I recently got a cable connection. My old Netgear set up really easily, but I am having trouble getting this cable one to see the connection.
Firstly, the Setup Wizard html file on the CD doesn't work, as it opens but there is a broken image link on the html file for some reason. Having set up my old router I'd like to think I could do without this, if I could just connect to it.
When I've plugged it in, the power, wireless, internet and LAN port lights are fine, but the "test" one isn't on, apart from briefly at the start when I turn it on. I don't know if this is normal or not. Any attempt to connect to the router with http://192.168.0.1 (or http://192.168.1.1 as it says on the bottom of the router) takes a long time trying to connect and then the connection times out. Same with www.routerlogin.net, and www.routerlogin.com.
From my Googling, I have a feeling this is something to do with the fact a Telewest cable modem only works with one MAC address at a time. Some suggestions say to spoof my iBook's MAC address as the routers, and some say that this is no longer necessary (as does Telewest's website). The official stance seems to be to shut down the computer, power off the modem for 2 minutes, disconnect the cable from the computer and plug it into the new device (i.e. the router), power the modem back up and then power on the new device (router). I've tried this to no avail.
Has anyone else had this problem? It's starting to frustrate me somewhat. If I do need to spoof the MAC address, I don't think I can do this until I can connect to the router on 192.168.0.1, which I can't get to at the moment.
Any solutions would be much appreciated, even of the "Is your computer switched on?" tech support variety, as I have maybe overlooked something very obvious.
Thanks.
