From the perspective of pure Power Consumption/Battery Life, in normal daily usage or idle/sleep mode, would the additional hardware in the Max, compared the Pro specs in the subject line:
+16 GPU cores (total of 32)
+32G RAM (total of 64G)
+3TB SSD (total of 4TB)
Have an impact in the Power Consumption or energy used?
When idle those extra pieces of hardware have to be powered up and energized, even if they are not being used, maybe a small amount of power but something at the end, or is it that efficient, that even, if they are not being used, they will draw 0 power?
Or, would the Pro configuration, be more efficient in Power Consumption? Is the MacBook Pro capable of fully shutting down the components not being used?
Thank you
Thank you
