Hi all,
Has anyone tried running Lubbos Fan Control and SMC Fan Control at the same time?
Is it going to create a problem if I run them both?
I run SMC Fan control at the standard speed of 2300 and set the Lubbo fan control at 2300 min and 50 degrees low and 80 degrees high threshold. The reason I like to run SMC is because it gives me a readout of both the fan speed and temperature.
Running just SMC at a particular speed just seems like a waste - I have to manually control the speed settings.
Do you think it's an issue to do it like this? Would there be a conflict if I never change the SMC settings?
Please let me know.
Thanks.
Cheers.
Please let me know.
Thanks.
Cheers.
