How do you set the bit rate for converting a CD song to mp3?
I found apple's tutorial page. It talks about opening itunes preferences... the only preference I find is under the EDIT heading. The next step is opening IMPORTING. The only importing I see is under the dropdown under FILE. None of that leads to setting any quality levels, whther MP3, WAV, or any of the other format...
I have the latest version of iTunes.
Thanks in advance. I'll keep searching in the meantime.
