Grasbak
434
16
UK
Help! I have an iDVD project I am burning onto DVD-R.
So far I have successfully burned 2 but have had 3 failures. Each time it failed it said "there was a problem buring multiplexing/burning"
Is my superdrive at fault or the DVDs?
Also, dont know if its related but when the DVD starts up spinning it makes a very loud "moo" - is this normal?
Thanks
I don't think you can slow iDVD's burn speed down but you can export the file and (if you don't have Toast) burn it in Disk Utility. Alternatively, try a different brand of blank DVD. :)
Yep - that seems to have worked.
Burned disk image then used Disk Utility to copy to DVD (at full speed).
Just seemed to work a lot better than through iDVD... a bug in iDVD perhaps?
Thanks
You're right.
I am used to using Toast.
