sfoxy
28
35
The Mac Studio has 4 separate Thunderbolt buses, so I assumed that would mean each would have its own power delivery. However, I already have 2 external Thunderbolt 3 NVMe enclosures attached, and when I try to attach a 3rd, it says there is not enough power for it. I have unplugged everything else and tried just the 3 enclosures, but get the same. They are cheap Acasis enclosures, so wondered if that was the issue, or is it jus that the Thunderbolt buses share power? When I spoke to Acasis, that is what they claim, that 2 buses share power.
I know that was true on older Macs, but is it still true in the Studio? Or has anyone successfully running more than 2 Thunderbolt drives?
EDIT: Should have mentioned this is M1 Max.
OldMike
Mar 3, 2009
537
219
Dallas, TX
This was recently discussed here:
Reactions: wdhpgx
OldMike
Mar 3, 2009
537
219
Dallas, TX
Just re-read the thread. From the following post:
It seems that it is possible to get three bust powered drives running before receiving the low power message. I am using all of my ports, but only have the bus powered enclosures hanging off of enclosures that have their own power.
sfoxy
28
35
Ah, thanks for that. I did search for Thunderbolt in titles, but not TB!
sfoxy
28
35
I just clarified my original post that I have the M1 Max which only has 4 TB ports, so that is why I am limited to 2 bus powered drives. Seems that pairs of ports are sharing power. Acasis do a powered enclosure, so may have to get that.
Falcon_64
Oct 26, 2017
103
153
I'm the OP on the thread that @OldMike linked to. My Studio has the Ultra, that's why I'm getting one more than you are able to use with your Max. I think it's odd that, despite being two Max chips and double the TB4 ports, I don't get to use twice the number of bus powered TB devices.
After seeing your post, though, I tested on my 14" MBP. I have a M1 Pro, not Max, but TB4 ports are identical. Like you on your Max Studio, I only can use two bus powered TB externals, the third fails.
