It means that if the part is replaced and stops working after 90 days, you will have to pay for another repair, unless you ask Apple to take another look and they agree to repair for free again.This means a new part only has to work for 90 days and then can break again?
Stage light effect developed which, according to the internet, is down to a faulty ribbon cable. Not sure how the rest of the laptop has anything to do with this.But the new part has been installed in an existing box with a lot of old parts already running. If any of those existing parts are no longer running at factory specs they may negatively affect the new part. Unless the box gets a full factory refurb I wouldn’t expect anything other than a minimal warranty for replacement parts.
The faulty ribbon cable problem could happen again, if they use the same original part(s) as the replacement. Be careful opening and closing your Mac. I would be very mindful of how far back you put the screen.Stage light effect developed which, according to the internet, is down to a faulty ribbon cable. Not sure how the rest of the laptop has anything to do with this.
With what part and where did they get it? A non-AASP that claims to replace with new OEM parts is lying to you.i had my MacBook Air (2018) screen replaced at a local computer store.
With @posguy99 post, I realized I misread your OP. The 90 day warranty I posted only applies to repairs made by Apple, unless the shop that did the repair is an Authorized Apple dealer. If they are not authorized, you need to ask them what the warranty is on that ribbon cable.Hi!
After just under 4 months the screen developed some issues.
Question: what’s the usual warranty on such parts here in the UK?
thÄnks!
