smdewart
26
I was hailing a cab in downtown Chicago the other day, when it began pouring rain. I had no umbrella, so while I knew I'd get wet, I was pretty sure my MacBook Pro would be safe in my vinyl briefcase.
Yet when I turned on my MBP later in the evening, there appeared large blotches of condensation/moisture inside the screen (as well as a large vertical rectangle that seemed far brighter than the rest of the screen). Oddly enough, everything works perfectly -- Internet/AirPort, apps, etc.
I immediately powered it off and placed it open, on its side, with a fan blowing. Two days later, the screen seems much better -- less moisture appears inside the LCD.
Is my LCD screwed? Should I wait to turn it on for a few more days? Will AppleCare cover this (assuming I play "dumb")? Anyone ever have such an experience??
well, my cell phone once went through the wash and it took about three days for all the moisture to come out, besides it smelling like detergent it worked fine. my advice is at least wait till it dries out, and if it's still blotchy/your having any problems go to applecare. You can at least try.
Moisture tends to be something Apple uses to deny Applecare coverage.
Do not turn it on until all water is gone. I would even go as far as taking the battery out. Just make certain it is dry before you power it on. You don't want the water to fry some circuits.
agreed. Do anything to save it. Water soaking through electronics=bad bad bad
