danny89
6
Hie, I have an iphone v1.1.3 unlocked which is currently not functioning after i updated the iphone to the latest update using the installer in my phone. After few hours, the phone switched off itself and now i cant even reboot it to safe mode. I tried to charge the phone then it came out the wire with itunes image. That is all i can go to. Then it will go off again after i pull the usb out of the charger. Please give some advice as well as guidance. Thank you.
rjohnstone
macrumors 68040
Dec 28, 2007
3,905
4,498
PHX, AZ.
Sounds like it's going into DFU mode when you plug it in.
So plug it in... when you are in DFU mode (Wire with iTunes image), start iTunes (a message will pop-up telling you the phone is in restore mode) and install the 1.1.4 update.
Once that is complete, download the LATEST version of ZiPhone and jailbreak and unlock it.
That should fix the problem.
danny89
6
the problem im facing is that when i try to remove the usb from the charger, the itunes image will disappear as soon as i pull the usb out of the charger. Hope you can give me more advice on this matter as its really giving me real bad headache. Thanks
danny89
6
An unknown error has occured (1601) shown when i was trying to plug into itunes and itunes showed that it cant be restored. PLS help ME!!
danny89
6
the itunes cannot search for the phone and it is unable to on. It cant even makes a recovery mode. pls help
alecapple
Feb 23, 2008
109
hold the sleep button for 30 secs so iphone is completly off, then while holding the home button connect into itunes and restore.
