hooldus
35
6
I've been hearing reports that the speakers on the new iPad Pro 11-inch M4 might not be as good as the previous generation, possibly due to the thinner design.
I'm considering either the new iPad Air 6 M2 11-inch or the iPad Pro M4 11-inch, and I’m specifically interested in the sound quality for listening to podcasts and YouTube at mid-volume.
I know the iPad Pro has four speakers while the iPad Air has two, but which model has better sound quality? Has anyone compared the two? Any insights or opinions would be greatly appreciated!
Reactions: aypues
No Air speaker can compare with the Quad of any of the Pro models
Pro models vary slightly generation to generation
However even the worst Pro will outdo any Air as clearly as night and day
The same way as any iPad or iPhone with 120 Hz that’s not underpowered will appear much snappier than all 60 Hz displays, doesn’t matter if the iPad with 120 Hz is from 2018 and the 60 Hz one from 2024
FYI my m4 13 is much louder than my m1 11 although the latter sounds slightly better
I'm sure the Pros have better speakers across the board but I don't think my 10.5" Pro sounded that much better than my 11" M2 Air. Neither are anywhere close the quality of the KEF LS50Ws or Focal Shape 65s that I use for critical or serious listening.
And about four speaker arrays, there is nothing inherently better about them versus two speakers for two channel audio. I assume that the Pro speaker arrays have other design characteristics that make them better than the two speaker arrays in the Air. Just adding speakers alone doesn't automatically improve anything. If it did, audiophile caliber speakers wouldn't be sold in pairs as they almost always are.
So ive just got the new 11” Pro and comparing to my 2018 Pro, the clarity is much better on this new one.
You’re thinking in the wrong direction
4 speakers in an iPad Pro means the sound will be mor4 balanced, less directional and overall louder, that’s the only difference
you can’t compare it to why a stereo might be more suitable than 5.1 for listening to music
