Status
@ISignedUpToAskThis Was just about to post the same! Bellroy improved on their leather case and it now has a glass camera control button for every iPhone. Their leather case was the only case I’ve kept on for 6+ months since Apple ditched their leather cases. They’re the closest to Apple’s leather in terms of thinness.
Already picked mine up in black: https://bellroy.com/products/phone-case?color=black&material=leather&size=i17pro#slide-0
I’m liking this Night Sky. Might wait until they’re available on Amazon for easier return if need be.
Oh well no Tech woven for me because I will only go with the normal 17, changed my choice after the event. Would have loved to try it. Guess it's going to be cheap ESR or Spigen Case for the start.
Reactions: Hooterville
How durable will the finishes be on these new anodized aluminum pros?
Orange be rubbing off and aluminum
shining through?
Orange is too beautiful to be hidden so I'm going to have to spring for a clear case. Problem is I've got used to having a case with a hidden two card slot on the back for my 12 Pro Max, thus allowing me to travel wallet free with my work pass and a physical credit card just in case. And if the case is clear, it won't hide the cards.
Decisions, decisions... Form vs function... 🤔
I really need Schrodinger's Pro Max case
Anyone have both the Apple Clear and dbrand Ghost 2.0 cases for 16 Pro? I am curious how they compare spec wise (height, width, depth and weight).
Did I hear the announcement correctly? Does the antenna band surround the camera bump?
I can see it on the side of the phone and on the side of the camera bump….
Either way, if the camera ring on new cases is metal, there might be an attenuation problem. Definitely something to consider.
Wife's Air Bumper and Crossbody Strap just arrived, she's very happy and can't wait to get her Air. 🙂
What's the material on the bumper like? Is it soft and a little flexible, or entirely rigid?
I'm considering the Air, going caseless at home, but with a bumper when going out for a little protection - but if it's very rigid, I'm concerned it might scratch the phone if taken on/off frequently
