My Studio M2 Max 12C/38C 64GB, 4TB SSD arrived. It's dead quiet for me, and my office space is very very quiet. Very happy so far.
That's what I thought. I'm VERY glad I got my Mini Pro then! It's working out quite well btw, haven't even heard fan noise with it yet. It is slower at graphics stuff than my Studio Max was, but that's a minor part of what I do.Ifixit have completed a tear down and found it’s the same internals as the first gen. No obvious cooler changes, it appears the only major change apart from the chips themselves is a fan curve change.
I think it's at the firmware level, but it can be controlled by external fan software. The problem is, I don't think any external apps offer precise curves and it's more difficult to lower the M1 Studio to below its default of 1,100RPM to 1,000RPM. I'd considered using software when I had the M1 Ultra, but I felt I don't want to rely on it, when it really should have been in the firmware at the start and the 2.2Khz whine was too annoying.Is the fan curve controlled by software or hardware in macOS?
Is there a difference in terms of resources when using a 3rd party app with a rule or fan curve set to ramp up the fans when temps rise on an M1 studio vs the new, internal fan curve on an M2 Studio?
I know it’s hardly a huge cpu overhead, I use my own fan settings on my MBP to up the speeds much earlier than apple decided on a 2012 MBP, just curious really
Buying now...
Why couldn't they include this same LED on the freakin MacBooks? Hard to tell when the laptop is on, off, or on standby...You are going going to love it. If it did not have a little LED on the front I would not know if it was on (when the display goes to sleep)
Well, not anytime soon, it seems. Maybe in the 2030s, when most likely, another redesign will be made? Cuz, after the release of the 15-inch MacBook Air, it is basically a guarantee that this minimalist design language will stay until the end of the decade, at least.I miss the days when;
1. The MacBooks had a glowing LED that used to slowly pulse when it was sleeping.
3. Had a little button you could press that would light up a few LED's on the side to show you the approximate battery charge level, when the lid was closed.
4. Had a glowing white backlit logo.
5. Did not automatically power on when you opened the lid.
At least we have got MagSafe back. Hopefully some of the above will come back as well.
Not all Mac Studio's (M1 or M2) have this fault/problem.No it is not. It is a fault, an error in design, confirmed by apple technician to me. You just cannot hear it.
well.
It could depend on your placement or the occasion. Mine is silent most of the time. The whine just happens randomly and only in a very silent room.
I gathered so many reports and people who installed 100s of Mac Studio said that EVERY studio they touched had the whine in the end.
Mine was for repairs at Apple and they confirmed it being there but within parameters. So...maybe there are slight variations in production lines etc. but IT IS A MAJOR ISSUE and if it is fixed in further models, I am happy. Silly me bought a first edition, so my crying is not too loud
Can you hear it without boosting it in post?I captured the whine on the new M2 Studio.
When pushing my Studio on multi-hour video upscalings - the fans were up to around 1,350. I noticed a faint but intermittent whine. One at 2.4Khz (same as the original Mac), which is less loud, and two more around 1.3Khz & 1.35Khz, which was more pronounced.
I think it's safe to say the original whine problem hasn't been completely fixed. But so far I've only experienced it under large loads - it hasn't occurred sub-1300 RPM
Audio attached:
[stops around 34sec - starts again around 40 sec, stops again around 1:14 - increased DB so you can hear it]
Yes, it's how I heard it in the first place.Can you hear it without boosting it in post?
Use your smart phone with an audio spectrum app. it wont be perfect, but it will be good enough for most things.Edit: what is the best way to test the noise level? I was thinking to use Handbrake and encode a 4K video. I don't have a mic to record the noise level.
I have an iPhone 12 Pro, what do you recommend?Use your smart phone with an audio spectrum app. it wont be perfect, but it will be good enough for most things.
I'm afraid I used my android phone for this, so I don't have an iPhone recommendation, though I'm sure someone else can come up with one.I have an iPhone 12 Pro, what do you recommend?
This guy:On another note, watching the YouTube videos it is clear that the state of tech reviewing is atrocious nowadays. Everything is just pure heuristics to them and they’ve got no idea how to utilise the compute. It’s like they can’t read a spec sheet, understand what the hardware is… does anyone run a channel where they cover things that isn’t just loads of panning on nice cameras and talking about video production? Someone who can actually push computers to their limits deterministically and make a decent analysis on it?
I tested the fans at full blast with Fans Control and recorded the sound with Voice Recorder, while holding the iPhone near the bottom vents:
Can someone let me know if this is a proper check?
I'm not familiar with Topaz Labs and what upscaling looks like in terms of CPU/GPU loading. Is it taking an hour+ of loading all the cores (and or GPU) to get the auto fan setting to spin up into audible whine territory?I don't know if forcing the fan speed will cause the whine to appear. It became apparent after a multi-hour session on Topaz Labs around 1350RPM.
Whilst the whine is still there, it's likely only going to be an issue under load. If that's the case I can live with the whine as it will happen infrequently during working hours. If it was appearing at idle speeds, it would have been a nightmare.
