Ipod Battery draining probloms
One way I have found to fix this is through the diagnostics menu. To get here, turn on your ipod. Next press both volume buttons, and the power button at the SAME TIME and hold. You are in the right place if the is a menu with yellow lettering that says N20 Snowfox. from here use the volume keys scroll down to Power. Press the wake button. scroll down to Drain Power. press the wake button. once there isnt even enough power to turn on the device, plug it into itunes. once it is done charging, youre ipod will have the right battery life. here is an artice on getting to the diagnostics screen... http://www.geek.com/articles/apple/how-to-access-diagnostic-mode-of-the-sixth-gen-ipod-nano-code-named-snowfox-20100921/
