Wow. Who knew seams could anger so many people. Frankly, every design aesthetic that Apple has ever revealed to the public has had a reason for its existence. Who knows if this is truly the real deal or not. I like it. A lot. It's different and certainly a fresh direction for Apple.
Also, screen size does not necessarily make for a happy pairing- the resolution and what's under the hood can win someone over as well.
Given the nod towards gaming that Apple did, it could be an AMAZING thing to see this phone have a back panel that can utilize gestures. Couple that with the 960 x ??? resolution that is being kicked around- gaming should be pretty nifty.
The one real thing I'm hoping to see is a lock screen that shows notifications.
Can't wait to see what happens and guess what- it's not that far away!
RE: Seams
I have a feeling this phone runs extremely hot. Those seams seem to be possibly channels for heat to escape the case. This phone definitely will not like water.:apple:
I guess I will get the 3GS. Ugly looking. I won't buy. The front facing camera doesn't mean enough for me to carry that thing around. All square like. I have enough squares in my life. So un-apple like. I will still bet 20 dollars that it's not real, but if it is it won't go into production.
How can you call the design un-Apple like? Have you taken a look at the MacBook Pro lately? Or the latest round of iMacs? Or the iPad, for that matter. This design is very much in line with recent Apple product designs.
The kind of design you may concider "Apple-like" with a lot of curvy shiny plastic is very 1998. This is the new Apple design. Thin, flush, less rounded, metal, and side-to-side glass.
Don't bother with common sense, it's not welcome here.
I guess you're right. I'm just surprised to see so many calling the design of the iPhone 4 "un-Apple like". It is, in fact very Apple-like. Apple anno 2010, that is.
Personally I find the new design 10 times cooler looking and more stylish than the present 3GS design. No more cheap looking glossy plastic back, and no more tacky bling-bling chrome finish on the frame. The new design is less girly, and more masculine. More business-like, if you will.
Yeah every one is right. They put the lines there for no reason at all.... FFS use your melon, of course they serve a purpose.... Steve will let you know what in June. I'm sure if they have some really good reason for them every one that was poo pooing them will all of a sudden love them. 🙄 ...
Yeah, I don't get all the idiots that think this is not a production part (at this late stage) or are decrying it because of the "seams." Because of the stupidity of places like Gizmodo and now this quasi-legal repair site, we don't even know that they are "seams." No one who has the access has bothered to even zoom in on them so we can see what they are.
Here are some good, possible explanations for those with no imagination or brains:
  1. If they are "seams" they would make the iPhone come apart in various handy ways. For instance the entire bottom piece (which contains the antennas), could be swappable.
  2. Since they aren't likely to be actual "seams" they could also fucntion to increase durability. The unibody construction will make the iPhone much more durable, but also rigid. That means if you dropped it, it would survive, but the glass front and back might tend to pop off because they are the only part of the design with mechanical "give." Ergo the "seams" provide just enough stress relief to stop this happening. This is a pretty standard engineering solution that's used all over.
  3. The "seams" occur at both sides of the bottom, and to the starboard of the headphone jack. These are the exact locations that accessory devices need to attach to the iPhone. The "seams" could easily function as grabbing points for said attachments given that the smooth hard aluminium surface would be hard to grab onto otherwise.
I personally favour them being there for a combination of point 2 and point 3. I'm sure there are lots of other possible reasonable explanations also.
Finally, to those that keep posting the alternative rendering of a "non-sandwich" iPhone ... please remember that design is not just about how something looks, it's about how it works and how it's put together as well.
Apple has a patent on the metal ring that holds the glass on the front of the iPhone and it's a rather brilliant design from a functional point of view. The new iPhone takes that and runs with it.
This new iPhone will be a godsend to places that attempt to repair iPhones. by undoing those two screws at the bottom and applying a suction cup to the glass on either side, the thing will pop open easily. It also looks like most of the parts are easily swappable and that they have moved away from the glue and tape.
This new design is ABSOLUTELY BRILLIANT and solves many design problems from the previous model. It's going to be the new gold standard whatever people think right now.
On top of that, ... if the glass cover is that new ceramic which because of the patent only Apple is able to use in mobile devices, and the new body is unibody which because of the patent only Apple is able to use in mobile devices, and if the glass is attached to the body on both sides by means of the metal tension ring which because of the patent only Apple is able to use in mobile devices, then no one will even be able to remotely copy this thing.
Nothing will come close to this in design chops for a long time and you armchair designers and engineers are about to be proved horribly wrong yet again.
This design is a slam dunk in the design world.
This is an accurate assessment of 95% of the activity here.
It's far more common for MacRumors participants to live in an effing dreamworld where Apple can suspend the laws of physics and the economics of consumer electronics manufacturing are irrelevant to running a profitable publicly owned corporation.
The most futile thing you can do here is post something that has a modicum of logical reasoning and analysis of the situation based on previous behavior by Apple. Spouting off brain-damaged nonsensical ramblings is far better received on this bboard.
The most futile thing you can do here is post something that has a modicum of logical reasoning and analysis of the situation based on previous behavior by Apple. Spouting off brain-damaged nonsensical ramblings is far better received in this bboard.
My my, who's a grumpy boy/girl today?
I love the new design, how can people say that it doesn't look like Apple?? Mac Mini... PB...Ipad...very similar. I'm very happy with the dual volume buttons. The seams aren't the best look, but mine will have a case on it anyway. This design makes the 3GS look tacky.
Guys, i would like to chime in on the whole LED notification discussion.
I have a Motorola Droid (shoot me) and i love the fact that it has a single multicolored LED on the top of the phone that pulses whenever i get a new text, if i miss a call, get an email/update, etc. (green = text, red = missed call, yellow = update, blue = mail) <-----i think thats what the code is. I mostly get the green light and the red light so im not COMPLETELY sure about the others.
It is EXTREMELY useful and i think it is one of the best features on the phone (note that i came from an enV2 as my previous phone).
I think that apple implementing some kind of similar system would be awesome! Obviously the coolest way of doing it, as others have suggested, is to make the home button pulse different colors depending on the notification.
You guys can keep denying the usefulness of such a notification indicator but once you use it, you will love it to death.
I dont know nor do I really care if these parts or the Gizmodo thing was real. but my question is this... If Apple is soo secretive about their unreleased products, How can 2 complete units and now these parts "slip through the cracks"? We had the Gizmodo unit, the other in Japan and now at a repair shop in South Carolina. Thoughts/discussion?
Chris
Seams...
...I think I know where all the anger stems from; we all harbor a secret loathing for the seam on our ball bags.
I for one like my seam. It's 'Applesque' and Steve Jobs would approve.
Like this one?
i am just speaking for myself when i say that i have no use for a blinking led on my phone, i have had this feature on a previous phone, and did not like it. i find it obtrusive & irritating. that you find it useful is fine, i am sure many people agree with you. No problem.
I don't know why you don't think it's not useful,
perhaps because we all use our devices differently?
i pick up my phone about once every hour and check new mails, missed SMS, my to do list etc. i don't need a blinking light. i do not need to be distracted from work or conversation by blinking notifications.
i can of course understand that others might enjoy this feature, but on a previous phone which had this blinking LED i covered it with tape after a couple of days. i like to have as little blinking and as few "notifications" around me as possible.
which is one reason i always liked apple stuff, remember those laptops with an array of blinking led for each activity? dreadful.
Perhaps habit.
Apple reportedly makes their employees turn off passcodes at work. This is so the Apple Worldwide Loyalty Teams (aka the "Apple Gestapo") can look at any private emails or phone calls to see if you've been leaking secrets.
really? didn't know this.
though you'd think the so-called apple gestapo would know how to get past a 4-digit pin number.
