Thanos812007
51
14
Let’s see the batteries capacities the iPhone 13 pro max was shipped against 4352mah
Thanos812007
51
14
Mine after 6 cycles fluctuates between 4382 and 4440 mah. Other phones had 200mah more battery than the original capacity!
Gymnut
macrumors 68000
Apr 18, 2003
1,887
28
Design capacity: 4352 mAh
Full Charge capacity: 4490 mAh
Cycle Count: 6
now i see it
macrumors G4
Jan 2, 2002
10,768
22,646
It would be more helpful if people also stated % capacity. For example, my new battery is 102% of design capacity
Shadowbech
macrumors G3
Oct 18, 2011
9,038
5,894
Sorry for my naivety but Is this a mac app only? I can’t see a uk version in the iOS App Store?
It’s a Mac app only. No longer on iOS app store. If you have a Mac, download and install and plug in your phone.
4352 is the design capacity. Mine shipped with 4496 MaH out of the box at full charge. It does up and down depending on use. Low as 4450 MaH. So far Cycle 1. Had to return launch day device and get a new one.
Reactions: Southernguy
Taz Mangus
macrumors 604
Mar 10, 2011
7,815
3,504
Launch Day 128GB
Design Capacity 4352 mAh
Full Charge Capacity 4463 mAh
Cycle Count 8
Manufacture Date 08/23/2021
Thanos812007
51
14
Also when u plug in to charge the percentage drops. i hope is a bug not battery problem, that others are mention when u restart the phone the battery percentage drops 4-5%
Reactions: PhillyGuy72
Thanos812007
51
14
Why did u return it?
Taz Mangus
macrumors 604
Mar 10, 2011
7,815
3,504
After I charge my phone, I notice that the percentage does not drop for maybe 1 or more hours. If I look at the battery life on Coconut Battery, I see a difference between what iOS is reporting and the actual battery level. It can vary from <1% to about 4%. When people restart their phones, iOS is reading the actual battery level and that is why the battery level drops after a restart. I wonder of this will be fixed in iOS 15.1.
PhillyGuy72
macrumors 68040
Sep 13, 2014
3,038
4,470
Philadelphia, PA USA
I was absolutely thrilled with the health Coconut and iMazing was showing (103- 104%)
Then came 15.0.2. :mad:
The health just hovers around 95%-96% now.
Phone Battery setting does show "100%" health.
As of 7:30 am, 10-14
Battery Current Charge: 4166 mAh (99.9%)
Battery Design Max. Charge: 4325 mAh
Battery Effective Max. Charge: 4172 mAh (96.5%)
Battery Charge Cycles: 6
*Also my battery charge shows 100% for a VERY long long time, almost freakishly long, 7, 8 hours. If I reboot the phone, then it shows 95, 96%. Seems like the number gets stuck.
Reactions: Fred Zed
Shadowbech
macrumors G3
Oct 18, 2011
9,038
5,894
My guess that would be that at this rate it could drop to 80% less than a year.
  • Angry
PhillyGuy72
macrumors 68040
Sep 13, 2014
3,038
4,470
So...the same d-mn problem I had with the iPhone 12 Pro Max, I'm thrilled. ?
One day short of 10 months old, the 12PM was at 83% health. (The health drain started way back in Feb., just shy of 2 months old)
Battery made by Desay, same maker as my old 12 Pro Max
Shadowbech
macrumors G3
Oct 18, 2011
9,038
5,894
Mine's also made by Desay and I think I have a good one. Also on 15.02 and I only charge up to 80%. Never charge 100% (only once in a while).
Not to mention that my battery was manufactured on Week of 8/16/21.
Shadowbech
macrumors G3
Oct 18, 2011
9,038
5,894
Manufacture date 8-30-21 ?
My launch day was also manufactured 8-30-21 and noticed that battery capacity dropping so no way I was going to keep it if I was going know if it was going to drop that fast. That's not the reason why I returned my launch day device. For me it was the screen tint issue that I had returned it and got a new one.
Taz Mangus
macrumors 604
Mar 10, 2011
7,815
3,504
I have seen an instance where my battery stayed at 85% for several hours before it dropped 1%. This seems to happen for me every time I charge my phone. I can see why the battery percentage will stay at 100% for a long time after it is charged, because of the battery max capacity. But why when I charge to 85% it stays at 85% for a long time as well.
Reactions: BigMcGuire
Shadowbech
macrumors G3
Oct 18, 2011
9,038
5,894
just charged my phone to 80% with the automation set and coconut reads 79%. It will stay to 80% until coconut battery will read to 75ish%. Just like when your phone is fully charge at 100%, phone will remain 100% until Coconut battery will read 94% then it will go down to 99% on the phone. It's normal.
While my phone reads 80%, here is what coconut battery reads currently.
Taz Mangus
macrumors 604
Mar 10, 2011
7,815
3,504
I have noticed that the margin of difference between Coconout Battery and what iOS is showing, is larger after the battery is charged and get smaller <1% as the battery is used more.
