Talerbaum4711
3
We have 2 AirPods Pro 2 and 2 AirPods Pro 1 and 3 Samsung Smart TV´s .
With the Pro2 we can not connect to Samsung TV with the Pro1 no Problem . Pro 2 no Sound but Volume Control .
Have someone the same problem ?
sjperformance
macrumors 68010
Oct 7, 2013
2,002
2,155
Miami 305
Reading on Reddit with LG tv’s too. I’m picking up my gen2’s today. Been using gen1’s since launch. I use them on my Samsung tv’s everyday. I hope this isn’t an issue.
sjperformance
macrumors 68010
Oct 7, 2013
2,002
2,155
Miami 305
Ok just got back from Apple Store with the APP gen 2. It’s defiantly your tv. On my Samsung smart tv they connect quick. They sound fine. They work fine. Noticed I get higher volume levels with them versus the gen 1’s.
DianaMR
macrumors 65816
Sep 12, 2016
1,050
1,882
I’ve never connected my AirPods to my Smart TV’s. How do you do that?
just!ns
Dec 27, 2016
33
17
Same here. New airpods Pro (with latest 5A377 firmware) do not play nice with Samsung TV (software version 2302) ... they will pair, sometimes, but sound is choppy. Then when changing the channel on cable box or other source the sound cuts out completely. Sad because Beats Fit Pros and AirPods Max work flawlessly ... even AirPods 3 worked well.
Reactions: Ledzzeppelin
sjperformance
macrumors 68010
Oct 7, 2013
2,002
2,155
Miami 305
I’m on 5A374 as well. Everything working fine. Hope it’s a quick fix for y’all.
sjperformance
macrumors 68010
Oct 7, 2013
2,002
2,155
Miami 305
Update: Doesn't work now while connected to my samsung smart TV. Noticed at night no volume/nothing. I believe there's a bug or something.
pand_057
Sep 26, 2022
unfortunately i have the same problem.
I talked to support, they said that they are not responsible for connecting to non-apple devices
Reactions: rich78m
just!ns
Dec 27, 2016
33
17
That sounds like something Samsung would say, but I think it's an apple problem. The AirPods 3, AirPods Max and Beats Fit Pro all work with my Samsung TV ... hopefully it's just a firmware update/fix for the APP 2nd Gens.
just!ns
Dec 27, 2016
33
17
I noticed this morning I'm also getting connection issues with my iMac (music cuts out and right ear switches to transparency mode for a few seconds). If there's no mention of a firmware fix in the near future I'm retuning them. Never been issues like this with other Apple branded ear/headphones.
sjperformance
macrumors 68010
Oct 7, 2013
2,002
2,155
Miami 305
Yeah this is not good. Hopefully an update will fix it. I use my airpods every night for the past 2 years to watch tv at night. No noise for my wife or the baby. This is a must for me. Glad I have my gen 1's and used those instead last night.
Reactions: Ladybug and just!ns
Ledzzeppelin
Sep 27, 2022
4
Exactly ! Hope for a fix from Apple side, Samsung had once every two years updates on their TV's firmware :D
Reactions: just!ns
RobertBlack01
Sep 27, 2022
8
2
Same issue here. Pro2s connect with no sound but volume control. If I pair really close to the TV its choppy sound.
Tried all the basic troubleshooting steps, no luck. Worked fine with the original pros. Bummer. Following thread, hoping for a quick resolution.
5A377 AirPods Firmware
Just updated Q6 TV to latest software(1330.5)
Ledzzeppelin
Sep 27, 2022
4
I found a quick temporary fix. On my TV after changing the channel the sound stops or getting choppy. Going to sound source and change to tv speakers and then to air pods pro 2 again, the sound comes back. Hope works for you.
sjperformance
macrumors 68010
Oct 7, 2013
2,002
2,155
Miami 305
Yeah this worked. I just went back to using my gen 1 for TV watching. Not happy about this though.
Talerbaum4711
3
Not working for me - try with 2 AirPods Gen2 on 3 different Samsung Smart TV QLED
ro888
Aug 10, 2020
Not working for me either, I have the AirPods pro 2 with the latest firmware pairing with a Samsung 8K TV. No sound and sometimes there is sound but it's extremely choppy. I have paired this TV with two other bluetooth headphones and it works fine. Hopefully a firmware update sorts this out. A bit disappointing...
LIVEFRMNYC
macrumors G3
Oct 27, 2009
8,877
10,986
My experience is, Samsung TVs in general suck when using BT headphones or buds. It’s either going to be choppy af, or unable to connect, with plenty of BT headphones or buds. Don’t know why. It one of a few reasons I’m moving away from Samsung TVs.
sjperformance
macrumors 68010
Oct 7, 2013
2,002
2,155
Miami 305
I have been using AirPods on my Samsung smart tv’s for many many years. Never had any issues what so ever. AirPods Pro gen2’s not working right with any smart tvs. Not happy about this.
sbhatia3
Oct 2, 2022
Even My new Airpod Pro 2 does not connect to Samsung TV while Airpod Pro 1 works fine with same TV. Hope Apple address it soon, its a Bug
ProgrammerDad
Oct 4, 2022
4
Bought them today, latest firmware. Unfortunatelly no sound when paired (zero problems on this part) to new samsung QLED 4K from 2022 line. Waiting for some fix..
