Does your launch day iPhone 15 Pro Max already charge with optimized battery charging pattern?
  • Yes
    Votes: 23 24.0%
  • No
    Votes: 73 76.0%
  • Total voters
    96
Is there any way to get the optimized charging to be controlled by the alarm?
Why making it complicated by learning my charging pattern, my working hours and location changes every day.
I just want the phone to be charged by the time my alarm goes off.
I have the same issue with my 15 Pro Max. Got it on launch day, and the optimized charging has not kicked in. It did work as expected on my 13 Pro Max. All required settings are correct.
I have an iPhone 15 Pro, got it on launch and optimised charging isn’t working for me either.
Does the significant location need to be turned on? I know Apple’s instruction says so but I was able to get optimized charging working on my iPhone 14 and 13 Pro without turning it on. Got my iPhone 15Pro on launch day and it hasn’t been working for me yet.
Reactions: haruhiko
Bought mine and got it launch day. Still no optimized charging on iPhone 15 pro. My old iPhone 14 pro optimize charged fine. Idk why it doesn’t just pull that information over when you restore from backup.
Reactions: Boardiesboi
Mine worked for a while and then went back to charging 100% so I use the 80% option. I only use about 20-30% a day, so 80% is more than plenty for me.
Launch day 15PM and still hasn’t kicked in.
Launch day 15 PM here. I just checked and it finally started last night. So it took 24 days.
How about if you put an alarm on for the morning - is it smart enough to know that's when you will be getting up so will use that for optimized charging and now have to 'learn' your routine?
Do you have System Customization and Significant Locations On? I have never turned these on and has always worked. My wife also doesn't have these enabled and optimized charging works. I am guessing we just have to wait a little longer.
