Good question. I think, as long as the work isn’t GPU intensive, you would see a similar (~10%) reduction in battery as with light usage. I don’t think anybody’s properly tested 24 vs 32 under any scenario, but I image it would have slightly better battery (an extra few percent).does the max draw more power for cpu-intensive, non-gpu-intensive tasks than the pro too? what about max 32gpu vs. 24 on same type of task?
Doesn’t this post illustrate the limitations of this scrutiny. If the machine is telling you you’ve used just 1% of battery life after an hour and a half of X or an hour of Y, then it’s not really giving you useful or reliable information as the logical outcome of that is that your battery can last for a hundred hours!!!I've had a very different experience with my 16in 32GB Max 1TB. With just browsing in Safari, Mail, Calendar, and using Messages, I got 1 hour 27 min before it started to read 99% with the screen at just under half brightness. With a medium workload in photo pro apps (Capture One, PS) it took 58 min before it reached 99%.
Agreed. We know that Apple doesn't drop from 100% reported battery life until it's actually somewhat lower (I think I read 95% as reported by Coconut battery).Doesn’t this post illustrate the limitations of this scrutiny. If the machine is telling you you’ve used just 1% of battery life after an hour and a half of X or an hour of Y, then it’s not really giving you useful or reliable information as the logical outcome of that is that your battery can last for a hundred hours!!!
It is really strange (and usual Apple user unfriendly attitude) that the laptop batteries can't be easily changed and replaced. If you are using the battery, in a short time the battery life decreases and you have no possibility just to change it for a new battery as anywhere else. Really weird.
So it means if you use the battery, in some not very long time its life will be close to zero and you can't do anything to change it. And you laptop will be of very low value and possibilities of use.I tend to agree, but to be fair, internal batteries have advantages in battery size and weight efficiency, and Apple's internal battery design in this generation (while not on par with the most repairable laptops today) is still a notable improvement over the last generation according to the iFixit teardown. Few laptops these days have externally removable batteries and many manufacturers (including Apple previously) choose even more restrictive options.
So it can be basically changed in some way - in an authorised Apple service ? And you pay just for the battery, not for the half of the laptop ?
Great to hear. Was this on the 32 core GPU?I was able to easily get an entire day of work (morning till night) on a full battery with the 16" MAX 32gb. I always charge at night so for me the battery is something I barely think about now (I used to have to charge my old 2.9ghz i7 at some point during the day.)
Well, do it like for the next 2-3 months and your battery will need lunch before lunch and soon breakfastI was able to easily get an entire day of work (morning till night) on a full battery with the 16" MAX 32gb. I always charge at night so for me the battery is something I barely think about now (I used to have to charge my old 2.9ghz i7 at some point during the day.)
I did a side by side Netflix and Amazon Stream and posted the results in another thread about this same topic. That thread linked here. That was with the two stock configuration. One M1 Pro with 16gb and one M1 Max with 332GB
Battery life on M1X PRO vs M1X MAX?
Notice in the first part of the first test he says only the Max is playing it smoothly. The Max is doing more processing, so it's not a good test of battery life while doing the same work. And that's where most of the difference in battery life went in the first test. The second test made more...forums.macrumors.com
It was post #129.
The conclusion was the battery life was nearly identical on that light usage, everyday test. With the screen at a normal level, I'm sure it would have gone 10+ hours. Very sorry but I can't spend 10+ hours replicating the same activity on 2 machines so I thought the continuous stream would be a good way to compare with identical loads.
Regarding the 100%. In general, both machines did not move off 100% for the first 30 minutes. On another day, I got nearly an hour before it moved off 100%. To confirm what everyone knows, that does not translate to a linear decline from there. You do not get 30 minutes of use per 1% of battery. The back half definitely drains faster.
The breakdown of my 7.5 hour test were 4.25 hours for the first 50% of battery meter. So 100% down to 50% lasted 4.5 hours. 50% to 5% only got 3 hours. Bit like toilet paper with the back half of the roll disappearing faster.
As another test I didn't include in the other post.
I started with both machines at 53% battery and streamed ESPN using Safari. After 2.75 hours, The Max had 13% battery left while the Pro only had 10%.
Charged them both up to 100%. After 2 hours, the Max had 87% left while the Pro had 84%.
Couple of callouts there.
1. I'd call that close enough but if anything, the Max was slightly better. This is only one usage scenario (albeit one that will be replicated frequently by many of us - binge watching Netflix!). I don't know if Netflix streaming is GPU intensive enough and that's why the the Max did better in this test. Just so everyone knows my bias, I'll be using the Pro going forward so I certainly would prefer the Pro were the resounding battery winner.
2. From 53% down to 13% is roughly 40%. Machines lasted 2.75 hours. From 100% to 87%/84%, lets just round it to 15%. So 15% of battery drain lasted 2 hours. If you double that to 30%, you'd get 4 hours. Just further confirmation that starting from 100% is deceptive.
Someone asked about the Intel i9. I noted this in the other post but will repeat here. In my stream test that these M1 machines lasted 7.5 hours, the 2019 Intel only lasted 2.75 hours.
Regardless of which machine you pick, the Max or the Pro, they both have extraordinary battery life for everyday use.
I still had 53% battery by the end of the day so maybe like 2-3 yearsWell, do it like for the next 2-3 months and your battery will need lunch before lunch and soon breakfast![]()
I agree completely on the heavy graphics away from a power outlet. I don't want to question anyone's workflow but I would think most people would be at a desk (even if offsite). I mean heck, my primary need before for extended power was international flights. But most seats have power now.Did you compare how hot they get including bottom during these tests?
Only info so far on temp for high gpu processes not CPU intensive or light load. ( and max was +12F during high gpu.)
Honestly don’t understand the off power high gpu load tests, because a) even the pro max duration is crazy compared to previous b) are you really going to do a ton of graphics work away from power?
Thanks for that. Sounds like one was not noticeably warmer than the other during the tests.I agree completely on the heavy graphics away from a power outlet. I don't want to question anyone's workflow but I would think most people would be at a desk (even if offsite). I mean heck, my primary need before for extended power was international flights. But most seats have power now.
I did not do any measurements of temp but did pick check the bottom occasionally. I would describe both as slightly warm. But as noted in my other post, nothing close to the fan coming on. Which is very different than my 2019 Intel b/c that fan would regularly kick on for little to no reason and then I'd just watch the battery percentage drop. Definitely not an issue on these machines.
Overall very pleased with the battery. Been on the M1 Pro most of this morning for 2 hours doing various things and am currently at 85% left.
Well, I have Macbook Air M1 for 9 months. I use it on the move and battery often. Now - battery condition marked as "poor" and battery life maybe 40% of the first days ...I still had 53% battery by the end of the day so maybe like 2-3 years![]()
As I understand it, Apple will replace it in that case.Well, I have Macbook Air M1 for 9 months. I use it on the move and battery often. Now - battery condition marked as "poor" and battery life maybe 40% of the first days ...
I have the M1 Pro 10-16core 1TB and the battery life is terrible, only getting 1hr or less playing Transport Fever 2.Has anybody tested whether the M1 Max impacts battery life under normal casual usage, versus the M1 Pro. Essentially, I want to know if the extra GPU cores in the M1 Max drain battery even if they’re “not being used”? I would expect the battery to drain quicker when, for example, exporting video, but it would also export faster, so that would be expected and acceptable.
i think with games, it really depends which games/title one plays. Battery is going to vary a lot.I have the M1 Pro 10-16core 1TB and the battery life is terrible, only getting 1hr or less playing Transport Fever 2.
And screen brightness.i think with games, it really depends which games/title one plays. Battery is going to vary a lot.
If I remember correctly apple will replace a battery with less than 80% capacity if it has less than 1000 charge cycles and/ or is less than 3 years old. Of course I just think you are a troll but that’s ok this info may be useful for someone.Well, I have Macbook Air M1 for 9 months. I use it on the move and battery often. Now - battery condition marked as "poor" and battery life maybe 40% of the first days ...
