7 hours I bet.But can I? Idle only got 9.5 hehe. We should all place bets. I’m thinking I’ll get only 6 hours of browsing and coding on 14 max/64Gb. I’ll install VS code tonight and start programming tomorrow.
I only got 6 on my M1 MBA.
I have a theory that these new macs, specially the Max, take up power and battery regardless of what you do. So a typical workload wouldn’t really tax the system so it would end up being similar battery to being idle.But can I? Idle only got 9.5 hehe. We should all place bets. I’m thinking I’ll get only 6 hours of browsing and coding on 14 max/64Gb. I’ll install VS code tonight and start programming tomorrow.
So it’s not a power sipping SOC, it’s a power consuming SOC and it consumes power even while doing nothing. But, because it’s so quick, light workloads shouldn’t affect battery life too much.
Let’s see![]()
Ya, I wonder as the CPU cores having same number as M1 Pro, how can it be draining more? Could it be the processor frequency is higher than M1 Pro? Or more GPU cores could also be affecting somehow?Apple did verify (according to one person's YT comments lol) that the max chips do draw more power, "even at idle".
Could they provide us with the ability to turn off cores when not in use? Maybe low power mode is "OK" doing most tasks.
Do you have the M1 Max 24 GPU or 32 GPU at 64G Ram?
Damn, that's disappointing. I hope there are software optimizations to come that will extend the battery life. The main reason I wanted this upgrade was to get a lot more battery life than I was getting out of my i7 Vega20. If I'm doing heavy photo editing, I can get 2-3 hours out of it. If the Max only gets 9.5 hours while doing nothing that does not bode well for photo editing on battery power.
I think the comment mentioned the GPU cores. It would be nice to disable them if possible lol. Kind of like how some laptops disable discrete GPU to save battery until the discrete is needed.
EDIT: Actually there's a good post in this forum saying it's probably RAM related (64GB here), can't fully turn off RAM or it'll lose the data!
I think it might be the RAM that is playing a factor in this. I'm comfortably getting around 10 hours of usage while browsing, watching YouTube. Discord open, Spotify playing music through the speakers. And using iMessage in between. Brightness is mostly set at 7 dots from 0 or 8 dots from 0.
I'm on a 14" M1 Max 32 GPU / 32GB RAM
Oh that's good to know.I think it might be the RAM that is playing a factor in this. I'm comfortably getting around 10 hours of usage while browsing, watching YouTube. Discord open, Spotify playing music through the speakers. And using iMessage in between. Brightness is mostly set at 7 dots from 0 or 8 dots from 0.
How did you find that config? Did you get it shipped? Nice! I wanted 32GB but the store only had 64GB. My 32GB config showed mid december delivery so I said, nah, lol.
I did use some very lightweight google chatting last night and the battery didn't seem to deplete much. I'll try doing some discord and youtube today amongst other things, I'm OK with less battery life running a max config.
sudo powermetrics --samplers cpu_power,gpu_power
We'll see, like another poster above said, they have a theory for doing trivial tasks, the battery won't drain much (vs. idle).
The fast charge is there, kind of like Tesla I guess lol. May run out during the day but plug it in for 30 minutes and you'll get another X hours.
Hi Exorthium,I think it might be the RAM that is playing a factor in this. I'm comfortably getting around 10 hours of usage while browsing, watching YouTube. Discord open, Spotify playing music through the speakers. And using iMessage in between. Brightness is mostly set at 7 dots from 0 or 8 dots from 0.
Do you have 32G or 64G RAM?I can confirm 6.8 hours. Tried today
This looks much lower than Apple's claim.View attachment 1899530
~7hrs with 15% left. Probably I'll get another 8hrs just like every day since I bought it.
16" M1 PRO/ 16gb / 512SSD
