Gentlemen, I present: https://www.apple.com/shop/product/MXK22AM/A/lightning-to-35-mm-audio-cable-12m-white
Proprietary, yes, but it also contains the DAC / DA Converter which is necessary for wired use.
The point of a meal is not to think about its price but to enjoy its taste. Similarly, the point of AirPods Max is to enjoy music, not to recollect its effect on your bank balanceAs good as they are, they are way too expensive
This is why I rarely believe anything this site says. It’s all just clickbait.2024 or 2025?!?!?! WTF Apple. How long was it between APP and APP2? I don’t think it was 4 1/2 years.
Hi Tim.
But seriously the max should be so much better.
How about a real case?![]()
Hi Tim.
For what they are they're a decent price. If you want cheaper over ear headphones there's lots of other options, including from Apple through the Beats end of things.Who bought AirPods max anyway.😆
Utter rip off
Same. I've been using them non-stop since early 2021. I finally had to get the battery replaced ($79) because I'd put at least 1000 hours of use on them and I was down to maybe 8 hours on a charge. They shut out everything, they're incredibly comfortable, the controls are very reliable and actually fun to use... and they sound amazing. I know I paid full-ass price for them, but frankly I forgot about that money ages ago.Sold. My current pair is the best headset I have owned.
Is there any pair of bluetooth headphones that delivers lossless music?You would think supporting lossless music would’ve been included even in the first generation Max…🙄
It is, unless you're also keeping rocks in there. I find mine fare quite well in a backpack surrounded by the normal things you put in a backpack -- and at the same time it's compact enough to leave room in said backpack for other stuff, unlike a fully-enclosed case does.The case should also be good enough to store the Max in a backpack. Go 🍎
The mesh part is exposed and can be punctured.It is, unless you're also keeping rocks in there. I find mine fare quite well in a backpack surrounded by the normal things you put in a backpack -- and at the same time it's compact enough to leave room in said backpack for other stuff, unlike a fully-enclosed case does.
I know, this is an unpopular opinion but I think the "bra" actually does an adequate job for its intended use. Does it look weird and sort of half-finished? Yes, yes it does. ¯\_(ツ)_/¯
By an errant pen? It's not as delicate as all that. And if you've got something sharper than a pen banging around in your backpack you've got bigger problems.The mesh part is exposed and can be punctured.
It's not just a pen. The corner of a book. A wallet can push through the mesh. An access card. An iPhone can push through the mesh. Keys can puncture the mesh.By an errant pen? It's not as delicate as all that. And if you've got something sharper than a pen banging around in your backpack you've got bigger problems.
LOL an iPhone or an access card is not going to "push through the mesh". It's not made from spider webs.It's not just a pen. The corner of a book. A wallet can push through the mesh. An access card. An iPhone can push through the mesh. Keys can puncture the mesh.
