Status
Good morning/afternoon.
Success.
You rule @joevt !! we are able to use the flashed NV evga 6200 PCI 512 card!
Sorry for the delay on answering, I was not able to get the 3.6V batt for the logical board until yesterday, it was empty the original one ;)
After several hours on telnet, we got to insert the nvramrc by means of nvedit as it was meant.
it was kind of difficult to understand the behaviour of inserting the <cr> string, for carriage return.
The nvramrc looks correct as the one You shared for PowerMac G5 1.6 PCI board.
We could again insert and fix with the screw the card, and rightnow the fans are not getting loud, and the systems boot fine 10.5 and 10.6 beta.
Many many thanks, for your quick and great support.
I'll try to test in on the next few days, but it seems to work fine.
If any debugging information or dump is needed, for sure I can try to add it to the thread.
All the best!!! PowerPc computer upgraded. Kind regards.
Reactions: joevt
quick little edit to teh first page
Original Question​
I have an old Power Macintosh G3 Minitower (266 Mhz) and I'm looking to install a GPU upgrade so the G3 can output higher resolution video at higher color depths. However, I don't know of any specs for what the max working graphics card specs (mainly VRAM) work for a beige G3. All I know is that the GPU would be installed in a PCI slot. Does anyone know of the maximum graphics card requirements for beige G3s? I could use those to search for graphics cards that would work (preferrably ATI since Apple used graphics cards from them back in the late 90s and early 2000s).
Simple Answer​
Radeon cards works in all PCI Macs but don't support Core Image. #2
Quartz Extreme may be enabled manually. #6
  • Rage 128
  • Radeon 7000
  • Radeon 7500
  • Radeon 8500
  • Radeon 9000 - #213
  • Radeon 9000 Pro - HERCULES #7 #9 #26 #205 #206
  • Radeon 9200 - most powerful video card an OldWorld Mac can use #4 #8 #228
Some Nvidia cards also work but are not as good as some of the Radeons #13
Complicated Answer​
Nvidia cards that support Core Image can work if their PCI ROM is modified for Old World Macs (see below). #2
When a GPU that supports Core Image exists, Core Image will be enabled for all GPUs #482 .
Quartz Extreme is enabled by default. #6
  • GeForce 5200
  • GeForce 5500
  • GeForce 6200 - PNY GeForce 6200 PCI, flashed and working fine in G4 towers. #32 #66 #68 #101 #223
    • Modified ROM #15 for @flyproductions 's PNY : #386
    • Modified ROM #16 for @DearthnVader 's PNY : #388
    • Modified ROMs #17b for those two which should work in all versions of Apple Open Firmware (not suitable for OpenBIOS unless it implements us for microsecond delays): #415
    • Modified ROM #18,19 for @domii's BFG 6200 bfgr62256ocp: #436 (may require nvstrap/clocks modification #446 ) -> #449 -> #450
    • Modified ROM #20 for @DearthnVader 's EVGA 6200 512MB (512P1N402LR) (for all versions of Apple Open Firmware) #656
  • GeForce 6600 - #228
  • GeForce 7800 GT - #234
    • Modified ROM #26 from Mac Edition, 64KB compressed and 128KB uncompressed versions (modified for all versions of Apple Open Firmware but only tested in Quad G5) : #28
  • GeForce 7800 GTX
Benchmarks​
While OpenMark-results are more or less resolution independent, those of OpenGL Extensions Viewer depend very much on the settings! So only same settings (resolution, color-depth etc.) can be compared to each other. Settings used are: Given resolution and color depth, Fullscreen, Standard-Framebuffer, anything else turned off. Also using the same version of the app is recommended, if results shall be compared. The respective versions of OpenGL Extensions Viewer for testing can be downloaded from post #718.
  • OpenGL Extensions Viewer 3.0 or 3.1.1 (OpenGL 1.1 scores)
    • 166 fps (1680x1050x32) (OpenGL 2.1) - GeForce 6200 PCI in G4 Sawtooth #223
    • 170 fps (1680x1050x32) (OpenGL 2.1) - GeForce 6200 AGP in G4 Sawtooth #223
    • 172 fps (1680x1050x16) (OpenGL 2.1) - GeForce 6200 PCI in Beige G3 #410
    • 240 fps (1920x1080x32) (OpenGL 1.5) - Radeon 9200 in G4 MDD #309
    • 269 fps (1680x1050x32) (OpenGL 1.5) - Radeon 9000 Pro PCI in G4 Sawtooth #223
    • 296 fps (1680x1050x32) (OpenGL 1.5) - Radeon 9000 Pro AGP in G4 Sawtooth #223
    • 278 fps (1920x1080x32) (OpenGL 1.5) - Radeon 9000 Pro in G4 MDD #309
    • 307 fps (1680x1050x16) (OpenGL 1.5) - Radeon 9000 Pro in Beige G3 #410
    • 824 fps (1680x1050x32) (OpenGL 2.1) - GeForce 6600GT in G4 QuickSilver #687
    • 849 fps (1680x1050x32) (OpenGL 2.1) - Radeon RX 6800 XT in G4 Sawtooth #223
    • 1041 fps (1280x1024x32) (OpenGL 2.1) - Radeon 9800 Pro in G5 1.8 #612
    • 1668 fps (1280x1024x32) (OpenGL 2.1) - GeForce 7800 GT in G5 1.8 #612
    • 2399 fps (1680x1050x32) (OpenGL 2.1) - Gainward Bliss 7800GS 512MB in G4 QuickSilver #687
    • 1331 fps (2560x1600x32) (OpenGL 2.1) - GeForce 7800 GTX 512MB in G5 Quad #731
    • 4021 fps (1344x1008x32) (OpenGL 2.1) - GeForce 7800 GTX 512MB in G5 Quad #731
  • OpenMark
    • 3612 (1280x1024x32) - GeForce 6200 in PowerTower Pro #685
    • 4147 (1680x1050x32) - GeForce 6200 in Beige G3 #413
    • 9331 (1280x1024x32) - Radeon 9800 Pro in G5 1.8 #612
    • 14709 (1280x1024x32) - GeForce 7800 GT in G5 1.8 #612
    • 19468 (2560x1600x32) - GeForce 7800 GTX 512MB in G5 Quad #731
  • xbench 1.3 (OpenGL Graphics Test - Spinning Squares)
    • 18.22 - 23.12 fps - GeForce 6200
    • 11.36 - 11.36 fps - Radeon 9200
PCI Adapters​
There exist adapters that may allow using PCIe/AGP/PCI-X/PCI cards in a different kind of slot. #228 #233 #237
  • PCI to AGP - Use an AGP card (e.g. Radeon 9800) that doesn't use AGP features in a PCI slot #38 #346
  • AGP to PCI - Use a PCI card in an AGP slot.
  • PCIe to AGP - Use an AGP card in a PCIe slot.
  • PCIe to/from PCI - PLX PEX8111 or PLX PEX8112 or IDT Tsi381 has PCIe 2.5 GT/s x1, 32-bit 33 MHz. The IDT has better performance than the PEX8111.
    • PCIe to PCI - Use a PCI card in a PCIe slot. ASMedia ASM1083 has PCIe 2.5 GT/s x1, 32-bit 33 MHz (forward only).
    • PCI to PCIe - Use a PCIe card (e.g. GeForce 7800 GT or Quadro FX 4500) in a PCI slot. #133
  • PCIe to/from PCI-X - PI7C9X130 or PLX PEX8114 has PCIe 2.5 GT/s x4, PCI-X 64-bit 133 MHz. #704
    • PCI-X should also allow PCI
PCI Speeds​
PCI
- 32-bit 33 MHz = 133 MB/s - original PCI Power Macs (7500, 8500, 9500, 9600, etc)
- 32-bit 66 MHz = 267 MB/s - Power Mac G3 (Blue & White), Power Mac G4 (PCI Graphics)
- 64-bit 33 MHz = 267 MB/s - Power Mac G3 (Blue & White), Power Mac G4, Power Mac G5 (PCI)
- 64-bit 66 MHz = 533 MB/s
AGP
- 32-bit 66 MHz 1X = 267 MB/s
- 32-bit 66 MHz 2X = 533 MB/s - Power Mac G4 (AGP Graphics), G4 (Gigabit)
- 32-bit 66 MHz 4X = 1067 MB/s - Power Mac G4 (Digital Audio), G4 (Quick Silver), G4 (Quick Silver), G4 (MDD), G4 (FW 800)
- 32-bit 66 MHz 8X = 2133 MB/s - Power Mac G5 (PCI), Power Mac G5 (PCI-X)
PCI-X
- 32-bit 100 MHz = 400 MB/s
- 32-bit 133 MHz = 533 MB/s
- 64-bit 100 MHz = 800 MB/s - Power Mac G5 (PCI-X)
- 64-bit 133 MHz = 1067 MB/s - Power Mac G5 (PCI-X)
PCI-X 2.0
- 32-bit 266 MHz = 1067 MB/s
- 32-bit 533 MHz = 2133 MB/s
- 64-bit 266 MHz = 2133 MB/s
- 64-bit 533 MHz = 4267 MB/s
PCIe
- 2.5 GT/s x1 = 250 MB/s - Power Mac G5 Dual or Quad Core
- 2.5 GT/s x2 = 500 MB/s
- 2.5 GT/s x4 = 1000 MB/s - Power Mac G5 Dual or Quad Core
- 2.5 GT/s x8 = 2000 MB/s - Power Mac G5 Dual or Quad Core
- 2.5 GT/s x16 = 4000 MB/s - Power Mac G5 Dual or Quad Core
- 5.0 GT/s x16 = 8000 MB/s
PCI ROM Modifications​
Power Macs use Open Firmware in their Boot ROM. Old PCs use BIOS. Intel Macs and newer PCs use UEFI.
A PCI card (this includes AGP and PCI-X and PCIe) contains a ROM that has one or more PCI Expansion ROM images. Each image has a type (BIOS, Open Firmware, EFI).
Any GPU that is going to work in a Power Mac requires a ROM that contains an Open Firmware image (also called FCode ROM).
Nvidia cards with 256 MB VRAM like the GeForce 6200 can be used, but they need modifications to their FCode ROMs to work with Old World Macs #386 . Example modified ROMs are linked above.
Old Worlds Macs are those with Open Firmware version 1.x or 2.x. New World Macs have Open Firmware 3 or 4. For Power Macs with Open Firmware 1.0.5, 256 MB doesn't work without the nvramrc patches that are usually added automatically by Mac OS 9 or Mac OS X or XPostFacto. This means the card could stop working after zapping the PRAM until you successfully boot into the Mac OS again.
...add links to XPostFacto nvramrc patches...
Nvidia cards with 512 MB VRAM only work with New World Macs that have Boot ROMs created September 23 2004 or later unless an nvramrc patch is used (with the modified FCode ROM in the case of Old World Macs). #460 #483
Is 512 MB VRAM useful? In some cases, yes #707 . Use OpenGL Driver Monitor to view the VRAM usage. #482
The nvramrc patch depends on the version of Open Firmware:
nvramrc Patches for PowerPC Macs to support GPUs up to 512MB​
for Power Mac 7500, 8500, 9500, 8600, 9600, Power Tower Pro, ...
The patch requires all the other map-in and map-out fixes from the Mac OS 9 or Mac OS X default nvramrc.
The default nvramrc added support 256MB BAR (up from 128MB). It should include:
- the helper functions (or aliases) $R and & (so you can remove those from my patch here).
- the mmr replacement (with mi) for fcode 89B map-range
- the two patches for fcode 8cb (map-in) which uses mcm and y
- the two patches for fcode 8c9 (allocate-addresses) which uses maa Note: maa needs to have 1D changed to 1E to support 512MB BAR.
- the patch for fcode 8cd probe-alloc
- the patch for fcode 8cc (map-out) which uses z.
- the patch for fcode 8c6 (alloc-mem-addr). This patch is separate from my patch of the same fcode.
(those names are from the XPostFacto nvramrc which may differ from the Mac OS 9 or Mac OS X version).
Code:
: $R BRpatch ;
: & get-token drop ;
: m5 { m } dup 1 1c << mmr 1 1c << + m 4+ ! 0 ;
8c6 & dup 58 + ' m5 4c + swap $R d0 + ' m5 10 + $R
Don't forget to also change maa as noted above.
for Beige G3
It reserves 2000 MB at the start instead of just 256 MB at a time so the first 5 lines for the patch for fcode 96e (alloc-mem-addr) might not be required.
The patch for fcode 971 (allocate-addresses) allows 512MB BARs to be included in assigned-addresses property.
Code:
: $R BRpatch ;
defer mr 944 & to mr
: m5 { m } dup 1 1c << mr 1 1c << + m 4+ ! 0 ;
96e & dup 3c + ' m5 44 + swap $R 9c + ' m5 c + $R
1e 971 & 1c + code!
for Power Mac 4400 and 7220 and some Motorola StarMax
Code:
: $R BRpatch ;
defer mr 940 & to mr
96a & dup 3c + ' m5 44 + swap $R 9c + ' m5 c + $R
1e 96d & 1c + code!
for Power Mac 5500, 6500, and TAM
It includes a patch that changes the order of PCI slot probing. It probes the ATI GPU (device @12) last instead of first. This fixes a problem where Open Firmware would not probe devices behind a PCI bridge (e.g. the USB and FireWire and ATA controllers of a Sonnet Tempo Trio). The patch should work with any such PCI card (the patches from Sonnet only worked with specific Sonnet cards). See #232
Code:
: $R BRpatch ;
1e 96d & 1c + code!
dev pci1
defer ?p
a3b & to ?p
: ps
0d 17 -1 ?p
0e 19 -1 ?p
0f 1c -1 ?p
11 16 -1 ?p
12 18 -1 ?p
' probe-slots dup
284 + ' ps blpatch
dup 288 + swap 2FC + $R
unselect-dev
for Power Express
Code:
: $R BRpatch ;
defer mr 970 & to mr
99a & dup 3c + ' m5 44 + swap $R 9c + ' m5 c + $R
1e 99d & 1c + code!
for Beige G3
Code:
: $R BRpatch ;
defer mr 948 & to mr
973 & dup 3c + ' m5 44 + swap $R a8 + ' m5 c + $R
1e 976 & 1c + code!
for Power Mac G3 (B&W)
Code:
: $R BRpatch ;
defer mr 8BA & to mr
8E3 & dup 3c + ' m5 44 + swap $R a8 + ' m5 c + $R
1e 8E6 & 1c + code!
for Power Mac G4 (AGP) Sawtooth, Power Mac G4 (Gigabit), Power Mac G4 (Digital Audio)
Code:
: $R BRpatch ;
defer mr 8e1 & to mr
90a & dup 3c + ' m5 44 + swap $R a8 + ' m5 c + $R
1e 90d & 1c + code!
for Power Mac G4 (Mirrored Drive Doors)
Code:
: $R BRpatch ;
defer mr 1707 & to mr
1732 & dup 3c + ' m5 44 + swap $R a8 + ' m5 c + $R
1e 1735 & 1c + code!
for Power Mac G4 (FW 800)
Code:
: $R BRpatch ;
defer mr 17df & to mr
180a & dup 3c + ' m5 44 + swap $R c8 + ' m5 c + $R
1e 180d & 1c + code!
for Power Mac G5 1.6 (PCI)
Code:
: $R BRpatch ;
defer mr 18e1 & to mr
190c & dup 3c + ' m5 44 + swap $R c8 + ' m5 c + $R
1e 190f & 1c + code!
Has support for up to 512MB BAR built-in.
for Power Mac G5 Quad
Tested PCI cards​
  • 6200 512MB in G4 Sawtooth #605
  • Quadro FX 4500 512MB in G3 (Blue & White) #651 (using PCI to PCIe adapter)
  • EVGA 6200 512MB (512P1N402LR) in Beige G3 may have problems #686
Notes​
  • The default nvramrc stored by Mac OS 9 or Mac OS X may already have parts of the provided patches (such as : $R BRpatch ;).
  • Since Mac OS 9 or Mac OS X may overwrite the nvramrc, you may want to include the patch in the Ofpt resources that the nvramrc contents originate from. #465 #475 #477
  • For some unknown reason, (allocate-addresses) for firmwares starting from September 2005 (such as for G5 Quad) loops through BARs by size in reverse order (starting from 512MB) when there's a 512MB BAR. I did not include that change in these patches. (allocate-addresses) for older Macs always loops from small (16 bytes) to large (128MB originally for OF 1.0.5, then 256MB with the OF 1.0.5 Mac OS 9/Mac OS X nvramrc patch, then 256MB for OF 2.0 and later, now 512MB with this patch or for firmwares starting from September 2004.
  • Open Firmware 3 is used by Macs with G3 or G4. Open Firmware 4 is used by Macs with G5. Both Open Firmware versions continued to be developed in parallel until their last versions created around at least the end of September 2005 or beginning of October 2005. Open Firmware 3 has versions 4.x.x while Open Firmware 4 has versions 5.x.x. #627
Troubleshooting​
  • Test the patch without the 512MB GPU. The Power Mac should boot into Mac OS 9 or Mac OS X.
  • Provide output from dev / ls unselect-dev " devalias" evaluate " printenv" evaluate dump-device-tree words. This will provide info about the hardware and some info about the Open Firmware environment. printenv outputs nvramrc only in some versions of Open Firmware. If the words we want to patch are not in the words output, then the get-token method of finding the words to patch will be used.
  • For a specific GPU device the output of .properties before and after the patch may be interesting. In particular, we want to see a BAR in the reg and assigned-addresses properties with size of 20000000 or larger.
  • Provide a rom dump (4MB for Old World Macs and 1MB for New World Macs #88 #95 ). A rom dump gives access to fcode images which can be translated to Open Firmware Forth code for easier readability. It will include visible and invisible forth word definitions. A rom dump will also include nvramrc contents. See "Dumping the New World Rom.txt" in the attachment at #137 . Also see #682 .
    Some Mac ROMs:Mac Open Firmware disassemblies and Forth code: #543
  • Provide a Open Firmware dictionary dump. See #137 #506 #682 . The fcode images are compiled into the Open Firmware dictionary as PowerPC instructions. The patches modify the PowerPC instructions in the Open Firmware dictionary.
  • Have a method of zapping the pram ready (how do you zap the pram of B&W G3 if the keyboard's not working? unplugging the power and battery for awhile should work).
List of Open Firmware versions​
Code:
√ = got it
x = got broken?
- = don't got it
        BAR   Boot   Boot   Boot   Boot   Boot   Sound
    Mac                                         OF version                             ATY,Fcode versions                         max   FW     USB    SATA   SCSI-X GPT    Arch             Notes
√   TNT Development A5c1                        Open Firmware, 0.992j                  None                                       128   No     No     No     No     No
√   7500,9500,8600,9600,Power Tower Pro, etc.   Open Firmware, 1.0.5                   None                                       128   No     No     No     No     No                      256MB BAR requires Mac OS 9 or Mac OS X nvramrc patches (see PowerSurge.of of joevt/XPostFacto for documentation of patches)
√   Apple Network Server ANS 500                OpenFirmware1.1.22                     None                                       128   No     No     No     No     No
√   Power Mac 5400,6400, UMAX SuperMac C600     Open Firmware, 2.0                     None                                       256   No     No     No     No     No
√   Beige G3 Desktop                            Open Firmware, 2.0f1                   1.49, 1.49                                 256   No     No     No     No     No
√   Beige G3 Minitower                          Open Firmware, 2.0f1                   1.49, 1.53                                 256   No     No     No     No     No
√   PowerBook G3 3400c                          Open Firmware, 2.0.1                   None                                       256   No     No     No     No     No
√   PowerBook G3 Kanga                          Open Firmware, 2.0.1                   None                                       256   No     No     No     No     No                      AAPL,3500
√   PowerBook G3 Wallstreet                     Open Firmware, 2.0.1                   1.54                                       256   No     No     No     No     No
√   PowerBook G3 Wallstreet PDQ                 Open Firmware, 2.0.1                   1.54, 1.59                                 256   No     No     No     No     No
√   Power Mac 4400 and 7220, Motorola StarMax   Open Firmware, 2.0.2                   APL-1.0b33                                 256   No     No     No     No     No
√   Power Mac 6500,TAM                          Open Firmware, 2.0.3                   APL-1.0b33                                 256   No     No     No     No     No
x   Power Express                               Open Firmware 2.0a9                    None                                       256   No     No     No     No     No
x   Power Express                               Open Firmware 2.3                      None                                       256   No     No     No     No     No
√   Beige G3 (v3)                               Open Firmware, 2.4                     1.49, 1.53                                 256   No     No     No     No     No
√   Beige G3 (v4)                               Open Firmware, 2.4                     1.49, 1.53                                 256   No     No     No     No     No
-   iMac                                        OpenFirmware 3 Open Firmware 3.0.f8    ?                                          ?     ?      ?      No     No     No                      Apple iMac                         built on 08/06/98 at 12:04:16
-   iMac                                        OpenFirmware 3 Open Firmware 3.0.b2    ?                                          ?     ?      ?      No     No     No                      Apple iMac                         built on 09/17/98 at 15:19:23
-   iMac                                        OpenFirmware 3 Open Firmware 3.0.f3    ?                                          ?     ?      ?      No     No     No                      Apple iMac                         built on 12/02/98 at 10:25:41
-   iMac                                        OpenFirmware 3 Open Firmware 3.0.f9    ?                                          ?     ?      ?      No     No     No                      Apple iMac                         built on 02/03/99 at 16:45:21
-   iMac                                        OpenFirmware 3 Open Firmware 3.0.f10   ?                                          ?     ?      ?      No     No     No                      Apple iMac                         built on 03/05/99 at 21:14:19
-   iMac                                        OpenFirmware 3 Open Firmware 3.0.f1    ?                                          ?     ?      ?      No     No     No                      Apple iMac                         built on 04/01/99 at 16:47:10
√   PowerBook G3 Bronze Keyboard (Lombard)      OpenFirmware 3                         1.63                                       256   No     No*    No     No     No                      Apple PowerBook1,1 1.0f1   BootROM built on 04/06/99 at 10:21:59
√   Power Mac G3 (Blue & White) Yosemite        OpenFirmware 3.1.1                     None                                       256   No     No     No     No     No                      Apple PowerMac1,1  1.1f4   BootROM built on 04/09/99 at 13:57:32
√   Power Mac G4 (PCI Graphics) Yikes           OpenFirmware 3.1.1                     None                                       256   No     No     No     No     No                      Apple PowerMac1,2  1.2f2   BootROM built on 08/19/99 at 21:36:38
√   iMac G3 (233 MHz) (Bondi Blue)              OpenFirmware 3 Open Firmware 3.0.f2    1.63, 1.64                                 256   No     No     No     No     No                      Apple iMac         1.3f2           built on 04/23/99 at 14:31:03
√   iMac G3 (266/333 MHz) (patched)             OpenFirmware 3 Open Firmware 3.0.f2    1.63, 1.64                                 256   No     No     No     No     No                      Apple iMac         1.3f2           built on 04/23/99 at 14:31:03
√   iMac G3 (266/333 MHz)                       OpenFirmware 3 Open Firmware 3.0.f3    1.63, 1.64                                 256   No     No     No     No     No                      Apple iMac         1.3f3           built on 07/16/99 at 12:15:09
√   Firmware Updater 3.2.4f1                    OpenFirmware 3                         1.69, 1.69, 1.71                           256   Yes    Yes    No     No     No                      *                  2.4f1   BootROM built on 02/18/00 at 09:44:35 (3.2.4f1)
√   Power Mac G4 (AGP Graphics) Sawtooth        OpenFirmware 3                         1.69, 1.69, 1.71                           256   Yes    Yes    No     No     No                      Apple PowerMac3,1  2.4f1   BootROM built on 02/18/00 at 09:44:51 (3.2.4f1)
√   Firmware Updater 3.2.7f2                    OpenFirmware 3                         1.69, 1.69, 1.71                           256   Yes    Yes    No     No     No                      *                  2.7f2   BootROM built on 08/13/00 at 10:41:50 (3.2.7f2)
-   Summer 2000 iMac DV+ (450MHz)               OpenFirmware 3                         ?                                          ?     ?      Yes    No     No     No                      Apple PowerMac2,2  3.0f3   BootROM built on 06/13/00 at ??:??:?? (3.3.0f3)
√   Power Mac G4 Cube                           OpenFirmware 3                         1.69, 1.69, 1.73, 1.74                     256   Yes    Yes    No     No     No                      Apple PowerMac5,1  3.2f1   BootROM built on 07/10/00 at 17:11:57 (3.3.2f1)
√   Power Mac G4 (Digital Audio)                OpenFirmware 3                         1.69, 1.69, 1.73, 1.75, 1.75               256   Yes    Yes    No     No     No                      Apple PowerMac3,4  4.1.0f1 BootROM built on 12/04/00 at 19:29:52
√   Firmware Updater 4.1.7f4                    OpenFirmware 3                         1.69, 1.69, 1.73, 1.77, 1.77               256   Yes    Yes    No     No     No                      *                  4.1.7f4 BootROM built on 03/20/01 at 17:20:48
√   iBook G3                                    OpenFirmware 3                         1.69, 1.69, 1.73, 1.77, 1.77               256   Yes    Yes    No     No     No                      Apple PowerBook2,1 4.1.7f4 BootROM built on 03/20/01 at 17:20:48
√   Firmware Updater 4.1.8f5                    OpenFirmware 3                         1.69, 1.69, 1.73, 1.77, 1.77               256   Yes    Yes    No     No     No     0x0e+0x12        *                  4.1.8f5 BootROM built on 03/21/01 at 11:49:53
√   PowerBook G3 (FireWire) Pismo               OpenFirmware 3                         1.69, 1.69, 1.73, 1.77, 1.77               256   Yes    Yes    No     No     No     0x0e+0x12        Apple PowerBook3,1 4.1.8f5 BootROM built on 03/21/01 at 11:49:53
√   Firmware Updater 4.1.9f1                    OpenFirmware 3                         1.69, 1.69, 1.73, 1.77, 1.77               256   Yes    Yes    No     No     No     0x0e+0x12        *                  4.1.9f1 BootROM built on 09/14/01 at 13:18:04
√   iMac G3 (Slot Loading)                      OpenFirmware 3                         1.69, 1.69, 1.73, 1.77, 1.77               256   Yes    Yes    No     No     No     0x0e+0x12        Apple PowerMac2,1  4.1.9f1 BootROM built on 09/14/01 at 13:18:04
√   Power Mac G4 Cube                           OpenFirmware 3                         1.69, 1.69, 1.73, 1.77, 1.77               256   Yes    Yes    No     No     No     0x0e+0x12        Apple PowerMac5,1  4.1.9f1 BootROM built on 09/14/01 at 13:18:04
-   Power Mac G4 (Quicksilver)                  OpenFirmware 3                         ?                                          ?     ?      ?      No     No     No                      Apple PowerMac3,5  4.2.3f1 BootROM built on 08/01/01 at 11:14:42
√   Power Mac G4 (Quicksilver)                  OpenFirmware 3                         1.69, 1.69, 1.73, 1.77, 1.79, 1.81, 1.77   256   Yes    Yes    No     No     No                      Apple PowerMac3,5  4.2.5f1 BootROM built on 08/16/01 at 22:19:35
√   Firmware Updater 4.2.8f1                    OpenFirmware 3                         1.69, 1.69, 1.73, 1.77, 1.77               256   Yes    Yes    No     No     No     0x0e+0x12        *                  4.2.8f1 BootROM built on 10/11/01 at 14:12:47
√   Power Mac G4 (AGP Graphics) Sawtooth        OpenFirmware 3                         1.69, 1.69, 1.73, 1.77, 1.77               256   Yes    Yes    No     No     No     0x0e+0x12        Apple PowerMac3,1  4.2.8f1 BootROM built on 10/11/01 at 14:12:47
-   Power Mac G4 (Gigabit Ethernet)             OpenFirmware 3                         1.69, 1.69, 1.73, 1.77, 1.77               256   Yes    Yes    No     No     No                      Apple PowerMac3,3  4.2.8f1 BootROM built on 10/11/01 at 14:12:47
√   Power Mac G4 (Digital Audio)                OpenFirmware 3                         1.69, 1.69, 1.73, 1.77, 1.77               256   Yes    Yes    No     No     No                      Apple PowerMac3,4  4.2.8f1 BootROM built on 10/11/01 at 14:12:47 ; last version with only 12 bit fcode numbers
√   Firmware Updater 4.2.9f1                    OpenFirmware 3                         1.69, 1.69, 1.73, 1.77, 1.79, 1.82         256   Yes    Yes    No     No     No                      *                  4.2.9f1 BootROM built on 11/20/01 at 14:31:20 ; first version with 16 bit fcode numbers
√   iMac G4                                     OpenFirmware 3                         1.69, 1.69, 1.73, 1.77, 1.82, 1.83, 1.83   256   Yes    Yes    No     No     No                      Apple PowerMac4,2  4.4.0f1 BootROM built on 04/08/02 at 22:45:14
√   iMac G4 17 inch                             OpenFirmware 3                         1.73, 1.77, 1.83, 1.86, 1.86               256   Yes    Yes    No     No     No                      Apple PowerMac4,5  4.4.5f3 BootROM built on 07/23/02 at 13:58:33
√   Firmware Updater 4.4.8f2                    OpenFirmware 3                         1.73, 1.77, 1.83, 1.86, 1.86               256   Yes    Yes    No     No     No     0x0e+0x12        *                  4.4.8f2 BootROM built on 09/30/02 at 10:24:31
√   Power Mac G4 (Mirrored Drive Doors)         OpenFirmware 3                         1.73, 1.77, 1.83, 1.86, 1.86               256   Yes    Yes    No     No     No     0x0e+0x12        Apple PowerMac3,6  4.4.8f2 BootROM built on 09/30/02 at 10:24:31
-   iBook G3 (Snow)                             OpenFirmware 3                         ?                                          ?     ?      ?      No     No     No                      Apple PowerBook4,1
-   iBook G3 (Snow)                             OpenFirmware 3                         ?                                          ?     ?      ?      No     No     No                      Apple PowerBook4,2
√   iBook G3 (Snow)                             OpenFirmware 3                         1.83, 1.87                                 256   Yes    Yes    No     No     No                      Apple PowerBook4,3 4.5.4f1 BootROM built on 11/11/02 at 16:06:29
√   Power Mac G4 (FW 800)                       OpenFirmware 3                         None                                       256   Yes    Yes    No     No     No                      Apple PowerMac3,6  4.5.7f1 BootROM built on 01/15/03 at 15:14:50
√   Power Mac G4 (FW 800)                       OpenFirmware 3                         None                                       256   Yes    Yes    No     No     No     0x0e+0x12        Apple PowerMac3,6  4.6.0f1 BootROM built on 02/20/03 at 13:52:27
√   PowerBook G4 1.0 GHz 17 inch (Aluminum)     OpenFirmware 3                         None                                       256   Yes    Yes    No     No     No                      Apple PowerBook5,1 4.6.2f1 BootROM built on 02/18/03 at 14:40:21
√   iBook G3 (Snow)                             OpenFirmware 3                         1.83, 1.87                                 256   Yes    Yes    No     No     No                      Apple PowerBook4,3 4.6.4f1 BootROM built on 03/15/03 at 10:16:09
-   iMac G4/1.0 17" (Flat Panel)                OpenFirmware 3                         ?                                          ?     ?      ?      No     No     No                      Apple PowerMac6,1  4.6.8f4 BootROM built on 08/22/03 at 13:45:20
√   Firmware Updater 5.1.4f0                    OpenFirmware 4                         None                                       256   Yes    Yes    Yes    No     No                      *                  5.1.4f0 BootROM built on 11/21/03 at 17:41:48
√   Firmware Updater 5.1.5f2                    OpenFirmware 4                         None                                       256   Yes    Yes    Yes    No     No                      *                  5.1.5f2 BootROM built on 09/21/04 at 11:58:53
√   Power Mac G5 1.6 (PCI)                      OpenFirmware 4                         None                                       256   Yes    Yes    Yes    No     No     0x0e+0x12        Apple PowerMac7,2  5.1.5f2 BootROM built on 09/21/04 at 11:58:53
√   iBook G4 (Early 2004)                       OpenFirmware 3                         1.92                                       512   Yes    Yes    Yes    No     No                      Apple PowerBook6,5 4.8.5f0 BootROM built on 04/06/04 at 16:22:09
-   Power Mac G5 1.8 (PCI-X)                    OpenFirmware 4                         ?                                          ?     ?      ?      ?      ?      No                      Apple PowerMac7,2
-   Power Mac G5 2.0 DP (PCI-X)                 OpenFirmware 4                         ?                                          ?     ?      ?      ?      ?      No                      Apple PowerMac7,2
-   Power Mac G5 1.8 DP (PCI-X)                 OpenFirmware 4                         ?                                          ?     ?      ?      ?      ?      No                      Apple PowerMac7,2
√   Firmware Updater 5.1.7f1                    OpenFirmware 4                         1.91, 1.92                                 512   Yes    Yes*   Yes    Yes    No                      *                  5.1.7f1 BootROM built on 08/25/04 at 15:11:09
√   iBook G4                                    OpenFirmware 3                         1.94                                       512   Yes    Yes*   Yes    Yes    No     0x0e+0x12        Apple PowerBook6,5 4.8.7f1 BootROM built on 09/23/04 at 16:13:38
√   Firmware Updater 5.1.8f7                    OpenFirmware 4                         1.91, 1.92                                 512   Yes    Yes*   Yes    Yes    No                      *                  5.1.8f7 BootROM built on 10/26/04 at 16:30:32
-   Power Mac G5 ? (one of the following 3)     OpenFirmware 4                         1.91, 1.92                                 512   Yes    Yes*   Yes    Yes    No                      Apple PowerMac7,3  5.1.8f7 BootROM built on 10/26/04 at 16:30:32
-   Power Mac G5 1.8 DP (PCI)                   OpenFirmware 4                         ?                                          ?     ?      ?      ?      ?      No                      Apple PowerMac7,3
-   Power Mac G5 2.0 DP (PCI-X 2)               OpenFirmware 4                         ?                                          ?     ?      ?      ?      ?      No                      Apple PowerMac7,3
-   Power Mac G5 2.5 DP (PCI-X)                 OpenFirmware 4                         ?                                          ?     ?      ?      ?      ?      No                      Apple PowerMac7,3
-   PowerBook G4 15 inch Early 2005 A1106       OpenFirmware 3                         ?                                          ?     ?      ?      ?      ?      No                      Apple PowerBook5,6 4.9.1f1 BootROM built on 01/21/05 at 10:51:16
√   Mac mini G4                                 OpenFirmware 3                         1.95                                       512   Yes    Yes*   Yes    Yes    No     0x0e+0x12        Apple PowerMac10,1 4.8.9f4 BootROM built on 03/23/05 at 14:22:23
√   Mac mini G4 1.5GHz Radeon 9200              OpenFirmware 3                         1.95                                       512   Yes    Yes*   Yes    Yes    Yes    0x0e+0x12        Apple PowerMac10,1 4.9.4f1 BootROM built on 07/12/05 at 16:57:27  ; last firmware to always allocate BARs by ascending size
√   PowerBook G4 DLSD                           OpenFirmware 3                         1.95                                       512   Yes    Yes*   Yes    Yes    Yes    0x0e+0x12        Apple PowerBook5,8 4.9.5f3 BootROM built on 09/22/05 at 16:17:32  ; allocates BARs by descending size when 512MB BAR exists
√   Power Mac G5 Quad                           OpenFirmware 4                         None                                       512   Yes    Yes*   Yes    Yes    Yes    0x0e+0x12|0x12   Apple PowerMac11,2 5.2.7f1 BootROM built on 09/30/05 at 15:31:03  ; allocates BARs by descending size when 512MB BAR exists
√   PowerBook G4 DLSD (17 inch)                 OpenFirmware 3                         1.95                                       512   Yes    Yes*   Yes    Yes    Yes    0x0e+0x12        Apple PowerBook5,9 4.9.6f0 BootROM built on 10/05/05 at 16:45:50
- BARs are allocated by ascending size except where noted.
- Patches exist to support 512MB BARs on all Power Macs.
- sound-architecture is in the config-block (0x100 bytes at 0xfff03f00 in the ROM) at offset 0x0e in the 3 most significant bits. If that is 7 than the byte at 0x12 is added.
BAR max - search for (allocate-addresses) ; 1c = 128 MB; 1d = 256 MB; 1e = 512 MB
Boot FW - search for findandadd-block-fw
Boot USB - search for findandadd-block-usb ; Yes* = needs patch ; No* = Lombard doesn't have "usb-ms-class" package, but does have code to look for it.
Boot SATA - search for findandadd-block-sata
Boot SCSI extended - search for findandadd-block-scsi-extended
NVStraps​
Every Nvidia card is different. You may need to modify the Nvidia soft straps in the Open Firmware image using the same info from a BIOS image. #243
For 512MB VRAM, you may need to modify the Nvidia soft straps to make sure the BAR1 reports as 512MB. #578 #581
The soft straps has a checksum #586 . There are some bytes that are unknown #631 .
Here's a script for dumping soft straps and checksum from a ROM file #589 #594 #601 .
The ROM code creates an NVDA,BMP property which contains performance info. This may also need to be updated #32 . Check the ROM Maker thread. #430
Incorrect info in the straps or BMP may cause issues in some apps. #410 #446 #449 #451
Also check device-id, subvendor-id, and subsystem-id #654
More info:
http://themacelite.wikidot.com/nv-rom
Editing nvramrc in Open Firmware​
Use the nvedit command in Open Firmware. There are special keys for navigation #185 . Type Control-C when done. Type nvstore to save changes. See below for more nvramrc notes.
Disabling a PCI device​
You may find it useful to disable the onboard graphics. This can be done by setting pci-probe-list. #11 #15 #18 #20 #156 XPostFacto might reset pci-probe-list #22 Therefore, you may want to put the setenv command in the nvramrc #29 . XPostFacto may change the nvramrc, so you may want to put the setenv command in the OFpt resource of XPostFacto where the nvramrc originates. #24 #25 Or maybe you don't have to #26 . Or maybe you do #58 #61 #87 .
The setting is renamed pci-probe-mask on New World Macs. #28 #137 #158
There exists pci-probe-history in some versions of Open Firmware. Bits can be set to cause probe-all to skip or redo a device. #49
OS Support​
The ROM of a Power Mac PCI card has an Open Firmware image which contains code for outputting video to a display connected to the GPU while in the Open Firmware environment.
Power Mac GPUs may include a NDRV in the Open Firmware image which contains code that is used by Mac OS 9 or Mac OS X for outputting video to a display connected to the GPU while in the OS environment. If it doesn't include an NDRV, then one from the OS may be used. The OS might not have an NDRV to use. #409 #455 #470 #472
Additional code is required in the OS for 3D acceleration, etc. You may need to run an Nvidia or Radeon installer for anything that is not included in the OS. #13
In a New World Mac, the Mac OS 8.6 TBXI Version 2.5.1 won't work with a GeForce FX 5200 or 6200 so I'd not be surprised if the even older Old World TBXI's also don't work so Mac OS 9 not booting may be a separate issue. #389 #194
New World Macs running Mac OS 9.2 should have no problem with the 6200 or 6600GT AGP (except there's no acceleration though). #391 #392 #411
Old World Macs have no boot picker, so holding the Option key just load defaults. #394
For 6200, I get CI support as long as I don't connect a display to an AGP CI supported card when I'm using the PCI card too. Seems to be a bug in OS X. #401
You may need to delete the kext cache #403 #407 .
In my brief testing with a G3 Blue & White a few years ago, you can boot 10.4.11 with a GeForce 6200 with a G3 CPU, but some 3D applications may fall over and die IIRC #408 .
One further quick note after "using" the Beige with the 6200 for a few days now:
- Dual displays works fine!
- If the Mac was turned off for some time, at the first attempt it allmost allways boots into a black screen. A second boot, either by holding the power button to hard shut down or rebooting via Screen Sharing when fully booted, usually brings it back to life. #425 #474
CPU Support​
A G4 may be required for OpenGL with the GeForce 6200. #458
Open Firmware Tools​
  • In Open Firmware
    • Some newer versions of Open Firmware may have a fcode-verbose? option to help debugging Open Firmware code. The way to use it is not documented. #40 Instead, Trace for Open Firmware was created. It works in all versions of Apple's Open Firmware. This has evolved starting from #123 #331 #356 #361
    • lspci for Open Firmware can list all PCI devices in Open Firmware for the currently selected PCI root. It extracts all PCI configuration space values and tests all the BARs. A bash script can interpret the results using lspci from pciutils. This has evolved starting from #50 #55 #64 #87 #97 #144 #273 #565
      • Sawtooth with 6800 xt on AGP, 6200 on the second of the PCI slots, a SATA controller on the last one #150
    • list-partitions - lists partitions of a hard disk in Open Firmware. #222 #225
    • dump-fields - list fields of some structures in Open Firmware. #25
  • In macOS #543
    • detok - from OpenBIOS - modified for Mac Boot ROM or PCI expansion ROM dumping.
    • toke - from OpenBIOS - modified for creating PCI Expansion ROMs from Open Firmware code. #129
    • lzss - from Apple Open Source - modified for decompressing Open Firmware stuff from New World Macs. #147 #151
    • DumpMacRom.sh dumps the Open Firmware parts of Mac ROMs (both Old World and New World).
    • DumpPCIRom.sh converts PCI Expansion ROM to Open Firmware Forth code which can be converted to FCode using toke #129 . The script can also extract individual images and concatenate them into a single expansion ROM #643 #720 .
Open Firmware Notes​
  • Open Firmware stacks #356
  • Open Firmware device nodes #25
Using dingusppc for Open Firmware Development​
dingusppc is a new emulator currently in development. I don't think it boots into Mac OS 9 or Mac OS X yet but it is useful for doing Apple Open Firmware testing. It works with Open Firmware 1.0.5, 2.0f1, and 2.4. I used it to develop some of the Open Firmware tools. #88 #117 #120 #124
Connecting to Open Firmware​
Connect to the Power Mac that will be running Open Firmware using serial or telnet #54 so you can paste commands from the other Mac or copy the output of Open Firmware commands.
  • Telnet only works with newer Power Macs (G4 and later) that have a telnet package. #60 #130 #131
    The Terminal.app doesn't have useful text pacing options so you may need to copy commands one line at a time #574 .
  • Serial: Use a Mac printer cable #62 .
    • The devalias is either ttya or scca #167 .
    • The default baud rate is 38.4Kbps but you can set 57.6Kbps. A nvramrc patch can be used to get 115.2 Kbps or 230.4 Kbps #64 #70 #76 #90 #107 #110 #112 . The patch depends on the version of Open Firmware.
    • Some Power Macs with a serial controller don't have a serial port. You may be able to install an adapter attached to an internal modem port. #615
    • For modern Macs that you want to connect to the Power Mac that is running Open Firmware, you can use a USB to serial adapter. These will be limited to 115.2Kbps. #196
    • Serial apps: #196
      • cu - terminal command
      • screen - terminal command
      • Z-Term - for old macOS
      • Serial.app - for modern macOS
Loading Files in Open Firmware​
In New World Macs, you can load files in Open Firmware from HFS+ formatted hard disk partitions.
In Old World Macs, this might be possible from FAT formatted floppy disks #59 #73 or from IDE CD-ROM drive with ISO9660 formatted CD #263 . floppy-emu might be convienent #272 .
The bootx file will load Open Firmware code for additional file systems #61 but I don't know how to get back into Open Firmware when that's loaded.
The load command can load an Open Firmware Forth script (begins with a comment which in Forth is a \ followed by a space) or it can load FCode. #71
load hd:,\6200debug.rom
The file is loaded at load-base and has size load-size
If you load a PCI ROM file which begins with a PCI header, then the load command may report an error and it will unmap the memory region (doesn't happen with OF 1.0.5 #267 ). You may be able to remap it using load_alloc. Examine the start to see if it contains the PCI header.
load-base 50 dump
The PCI Header starts with 55 AA. There's a PCIR signature at the start of the PCI Data Structure. The FCode starts with an F1 at offset 0x40 for the Nvidia ROMs we're testing.
Code:
00800000: 55 aa 40 00 00 00 00 00 00 00 00 00 00 00 00 00 |U.@.............|
00800010: 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 |........ .......|
00800020: 50 43 49 52 de 10 92 00 00 00 20 00 00 00 00 03 |PCIR...... .....|
00800030: a8 00 00 00 01 80 00 00 00 00 00 00 00 00 00 00 |................|
00800040: f1 08 16 5b 00 01 4f 4c 12 2a 00 00 00 00 00 00 |...[..OL.*......|
Instead of using load, you may be able to use (load) (which only works if (load) is a visible word, such as in Open Firmware 2.4) #305 #326 :
" ide0/@0:1,\TEST5.ROM" (load)
Executing Files in Open Firmware​
Once the file is loaded (see above), it can be executed.
If the code in the loaded file is to be applied to a specific device (such as for a PCI device), then before you execute it, you may need to do the following:
Select the device:
dev pci/@e
Override the default open word:
: open true ;
Fix some properties that the driver will expect (for example, the 7800GT Mac ROM requires subsystem-id to match the PCI config space value which is 0x52 - the driver will change this property to 0x10):
52 encode-int " subsystem-id" property
Open an instance and store the result in my-self #77 :
" pci/@e" open-dev to my-self
Optionally, set fcode-debug? so any named words will keep their names even if they are not external:
setenv fcode-debug? true
If it's a Forth script, then this will execute it:
load-base load-size evaluate
If it's FCode, then this will execute it:
load-base 1 byte-load
If it's a PCI option ROM where the FCode image starts at offset 0x40 (as it does in the PowerMac Nvidia ROMs we're testing), then this will execute it:
load-base 40 + 1 byte-load
Another option would be to remove the first 0x40 bytes. #266
After executing the ROM, undo some stuff #270 :
Code:
unselect-dev \ This should be all that is needed
device-end \ but we do this to be sure
0 to my-self \ and we do this too, just to be sure
PCI ROM Flashing​
After creating a ROM and testing it using file loading or emulator, you'll want to flash the ROM to the PCI card. A PCI card's ROM chip has a maximum size #141 #142 #165 . It might be 64K or 128K. A 128K ROM chip may allow both a BIOS and Open Firmware image. Some Nvidia ROM patchers require the first ROM image to be a BIOS image. See DumpPCIRom.sh above for a method to combine ROM images.
Testing ROMs in Open Firmware​
After doing the file loading method for testing ROMs, you will eventually want to test the ROM flashed to the PCI card. When Open Firmware starts, it initializes the Open Firmware dictionary and device-tree, executes the contents of nvramrc, then probe-all, install-console, banner in that order. The order can be changed (see #80 ). probe-all is when the ROM is executed. Any output emitted by the ROM is buffered and will not appear until install-console happens. I don't know what the limit is for buffered output #175 so it would be best to not have it buffered - make the output happen as the ROM is being executed. Add the following to nvramrc:
Code:
install-console
probe-all
banner
For Open Firmware 2.4, install-console in the nvramrc should be changed to (install-console) #123 #129 #178
Testing Display Output in Open Firmware​
While using telnet or serial, you can open a display device in Open Firmware and draw to the display.
For Open Firmware 2.x, draw color bars to screen without changing output #120 #191 :
Code:
screen open-dev drop
dev screen
10 0 do i i 28 * 0 28 d# 480 fill-rectangle loop
i have a bootrom version of 4.4.1f1 for my iMac PowerMac 4,2 - idk if you care to update the listing
I have made a note. You can use the attached "get-new-world-rom.command" in Mac OS X to dump the firmware into a file named "macrom#.bin" (where # is a unique number), zip the result, and post it here so I can examine it for more information.
  • flashrom-joevt-10.3 and 10.4-ppc 2024-11-03.zip
here ya go...
Thanks. I've updated the original post.
The 4.4.4.1f1 firmware is very similar to the 4.4.0f1 (they are both for the same model of iMac G4).
  • HWInit is identical except version and date.
  • Start is identical except version and date and checksum.
  • OF Part1 is identical except a startvec pointer to fcode images.
  • OF Part2 is identical except for:
    • version and date.
    • The main fcode image adds alt-mnp property (with value = 0x00000094) for the display for the PowerMac4,2 model.
    • Nvidia GeForce2 MX OF driver rom-revision changed from 1057.008.2 to 1057.008.4 and some additional code is added. What GPU does your iMac G4 have?
    • version and date.
I am pretty sure it is listed as Geforce2 MX in “about Mac.” It’s listed as the powerMac 4,2. Common name is iMac G4 700mhz. Let me know if I can give you any more info.
Hi guys. I don't know where else to ask for help.
I have B&W G3, PC ATI Radeon 7000 with 64 KB ROM (Pm25LD512) which I've tried to flash with every reduced rom available from The Mac Elite archive. I'm using raspberry PI and it's SPI to flash roms if it's important. All of the flashed roms leads to kernel panic at ~login window stage.
I've tried a completely clean and fresh installation of 10.4.11 and 10.4.6 with same results by cloning clean hdd image from QEMU.
The issue is my ATI Rage 128 has died, so I'm trying to restore Mac without original GPU.
I have managed to get Mac rom in single user mode using get-new-world-rom.command if it helps. Thanks in advance for any help.
  • macrom.bin.zip
Does the ATI Radeon 7000 appear in the device tree in Open Firmware? Does an image appear on the display when you enter Open Firmware?
I've looked at the 4 ROMs on the MacElite site.
I would not use "gotoh (reduced using new method)" because the new method is an incorrect method which messes up the Open Firmware stack.
That leaves choosing between the revision 208 or the revision 226 options (both 183 MHz).
Actually, the 208 revision reduced ROM has clock speed changed to 166 MHz.
What is the correct speed for your card? Do you have the original PC BIOS ROM?
That ROM is identical to another ROM I have from a B&W G3 (the NVRAM parts of the ROM are all zeros so there's no unique information stored in each ROM to make them different).
Make sure you have the ATI ROM Exender in the /System/Library/Extensions/AppleNDRV folder.
1. Seems it's appears.
2. Image also appears.
3. IOReg seems able to find it too.
Attached. It's Radeon Sapphire.
Trying to find it.
Currently it's flashed with 226 - not gotoh's new method, the other one.
Thanks for the help everyone.
  • backup.rom.zip
Trying to find it.
The reduced ROM's don't have an 'NDRV' it's required, the ATI ROM Xtender is a disk based 'NDRV' for all ATI Retail cards.
Is atiflash or flashrom or GraphicCelerator able to get the RefClk/SCLK/MCLK values from a PC ROM?
The latest ATI ROM Xtender I know of has version 1.2.5 from "ATI RADEON ROM Update.app" Aug 2005.
It seems that original rom frequency is 150.00. I'll reflash the GPU and try again.
I have another culprit in my mind. My GPU have only single VGA output (no dvi, etc...)
So probably it could be an issue? (Login window is trying to init second head).
Open Firmware is also showing 2 heads it seems.
Regarding ATI ROM Xtender - it's looks much better now, no instant kernel panics, even cursor moves, but still no desktop being displayed...
Logs attached.
How do you know it's 150?
Does reflashing the GPU change the speed or are you selecting a speed in the flasher?
What GPU is being used to produce the images in your photos?
The log says the second display is offline so I don't think it's a problem.
Code:
mrmidi@dorn:~/AtomDis $ python radeon_rom_final.py backup.rom
File:   backup.rom
METHOD: heur
BLOCK:  0x05EE
RefCLK: 27.00 MHz
SCLK:   150.00 MHz (Core)
MCLK:   150.00 MHz (Memory)
mrmidi@dorn:~/AtomDis $ python radeon_rom_final.py ATI.7000.32.Hyundai_010213.rom
File:   ATI.7000.32.Hyundai_010213.rom
METHOD: heur
BLOCK:  0x066E
RefCLK: 27.00 MHz
SCLK:   183.00 MHz (Core)
MCLK:   183.00 MHz (Memory)
mrmidi@dorn:~/AtomDis $ python radeon_rom_final.py Powercolor.7000.32.Elixir_040326.rom
File:   Powercolor.7000.32.Elixir_040326.rom
METHOD: heur
BLOCK:  0x0652
RefCLK: 27.00 MHz
SCLK:   133.00 MHz (Core)
MCLK:   133.00 MHz (Memory)
mrmidi@dorn:~/AtomDis $ python radeon_rom_final.py 226-padded.rom
File:   226-padded.rom
METHOD: database_mac
BLOCK:  Core @ 0x16F0, Mem @ 0x16E8
RefCLK: 27.00 MHz
mrmidi@dorn:~/AtomDis $ python radeon_rom_final.py 226-padded-150.rom
File:   226-padded-150.rom
RefCLK: 27.00 MHz
Seems pretty reliable for me.
Python:
#!/usr/bin/env python3
Radeon 7000 / RV100 ROM viewer & patcher.
Uses a database-driven approach for known ROM revisions for maximum accuracy.
Usage:
  # View ROM info:
    ./radeon_rom_final.py ROM.BIN
  # View with debug output:
    ./radeon_rom_final.py --debug ROM.BIN
  # Patch a ROM (RefCLK is read-only and not patchable):
    ./radeon_rom_final.py [--debug] IN.BIN OUT.BIN CoreMHz MemMHz
import sys, struct
DEBUG = False
def log(*args):
    if DEBUG:
        print("DEBUG:", *args)
# ─── Basic read/write primitives ──────────────────────────────────────────
r16 = lambda b, o: struct.unpack_from('<H', b, o)[0]
w16 = lambda b, o, v: b.__setitem__(slice(o, o+2), struct.pack('<H', v))
# ─── 1) Database of Known ROMs (Most Reliable Method) ───────────────────
# Format: (parsing_function, {extra_args...})
ROM_DATABASE = {
    # Mac ROMs (from Graphiccelerator's ROMDefs.xml)
    "113-85501-226": ('mac_db_parse', {'core_offset': 5872, 'mem_offset': 5864}),
    "113-85500-226": ('mac_db_parse', {'core_offset': 5872, 'mem_offset': 5864}),
def database_try(buf):
    rom_str = buf.decode('ascii', errors='ignore')
    for rev_str, (func_name, kwargs) in ROM_DATABASE.items():
        if rev_str in rom_str:
            log(f"database: Found known revision '{rev_str}'")
            # Call the specific parsing function for this ROM
            return globals()[func_name](buf, **kwargs)
    return None
def mac_db_parse(buf, core_offset, mem_offset):
    # This function is called by database_try for known Mac ROMs.
    if max(core_offset, mem_offset) + 3 > len(buf):
        return None
    # Read 24-bit BIG-ENDIAN value (kHz)
    core_khz = (buf[core_offset] << 16) | (buf[core_offset+1] << 8) | buf[core_offset+2]
    mem_khz  = (buf[mem_offset]  << 16) | (buf[mem_offset+1]  << 8) | buf[mem_offset+2]
    core_mhz = round(core_khz / 1000)
    mem_mhz  = round(mem_khz / 1000)
    ref_clk  = 27  # Assumed for Mac platforms
    log(f"mac_db_parse: Core={core_mhz}, Mem={mem_mhz}")
    return ('database_mac', core_offset, mem_offset, ref_clk, core_mhz, mem_mhz)
# ─── 2) Fallback Heuristic (Last Resort) ──────────────────────────────────
def heur_try(buf):
    log("heur_try: WARNING - Using unreliable heuristic method!")
    for off in range(0, len(buf) - 4, 2):
        a, b = r16(buf, off), r16(buf, off + 2)
        if a == b and 12000 <= a <= 25000:
            log(f"heur_try: Found matching values at 0x{off:04X}")
            return ('heur', off + 4, 27, a / 100.0, b / 100.0)
    return None
# ─── Helper: Find PC-BIOS header ──────────────────────────────────────────
def find_pc_bios(buf):
    for hdr in range(len(buf) - 0x20):
        if buf[hdr] == 0x55 and buf[hdr+1] == 0xAA:
            ptr = r16(buf, hdr + 0x18)
            pcir = hdr + ptr
            if pcir + 4 <= len(buf) and buf[pcir:pcir+4] == b'PCIR':
                log(f"pcbios: Found header at 0x{hdr:04X}, PCIR at 0x{pcir:04X}")
                return hdr
    return None
# ─── Master detect chain ──────────────────────────────────────────────────
def detect(buf):
    for fn in (database_try, heur_try):
        res = fn(buf)
        if res:
            log("detect: Success with method ->", res[0])
            return res
    return None
# ─── Checksum fix ─────────────────────────────────────────────────────────
def fix_cksum(b):
    rom_len_bytes = b[2] * 512 if b[2] > 0 else len(b)
    if rom_len_bytes > len(b): rom_len_bytes = len(b)
    cksum_range = b[0:rom_len_bytes]
    cksum_range[-1] = 0 # Temporarily zero out the checksum byte
    checksum = (-sum(cksum_range)) & 0xFF
    b[rom_len_bytes-1] = checksum
    log(f"checksum: Calculated {checksum:02X} for range {rom_len_bytes} bytes")
# ─── View routine ─────────────────────────────────────────────────────────
def view(path):
    try:
        rom = bytearray(open(path, 'rb').read())
    except FileNotFoundError:
        sys.exit(f"Error: File not found at '{path}'")
    info = detect(rom)
    if not info:
        sys.exit("Error: Could not find a recognizable clock table in the ROM.")
    mode = info[0]
    if mode == 'database_mac':
        _, co, me, ref, core, mem = info
        blk_info = f"Core @ 0x{co:04X}, Mem @ 0x{me:04X}"
    else:
        _, blk, ref, core, mem = info
        blk_info = f"0x{blk:04X}"
    print(f"File:   {path}")
    print(f"METHOD: {mode}")
    print(f"BLOCK:  {blk_info}")
    print(f"RefCLK: {ref:.2f} MHz")
    print(f"SCLK:   {core:.2f} MHz (Core)")
    print(f"MCLK:   {mem:.2f} MHz (Memory)")
# ─── Patch routine ────────────────────────────────────────────────────────
def patch(inp, outp, core, mem):
    core, mem = int(core), int(mem)
    try:
        rom = bytearray(open(inp, 'rb').read())
        sys.exit(f"Error: Input file not found at '{inp}'")
    info = detect(rom)
    if not info:
        sys.exit("Error: Cannot patch – no recognizable clock table found.")
    mode = info[0]
    print(f"Patching '{inp}' using method '{mode}'...")
        _, co, me, _, old_co, old_me = info
        print(f"  Old Clocks: Core={old_co} MHz, Mem={old_me} MHz")
        # Patch with 24-bit big-endian kHz values
        for off, val in ((co, core * 1000), (me, mem * 1000)):
            rom[off]     = (val >> 16) & 0xFF
            rom[off + 1] = (val >> 8)  & 0xFF
            rom[off + 2] = val         & 0xFF
        fix_cksum(rom)
    else:
        sys.exit(f"Error: Patching is not supported for the detected method '{mode}'.")
    open(outp, 'wb').write(rom)
    print(f"  New Clocks: Core={core} MHz, Mem={mem} MHz")
    print(f"Successfully saved patched ROM to '{outp}'")
# ─── Main entry point ─────────────────────────────────────────────────────
def main():
    global DEBUG
    args = sys.argv[1:]
    if not args:
        print(__doc__)
        sys.exit(1)
    if args[0] == '--debug':
        DEBUG = True
        args = args[1:]
    if len(args) == 1:
        view(args[0])
    elif len(args) == 4:
        # Args: IN_ROM OUT_ROM CORE_MHZ MEM_MHZ
        patch(inp=args[0], outp=args[1], core=args[2], mem=args[3])
    else:
        print("Error: Invalid number of arguments.")
        print(__doc__)
        sys.exit(1)
if __name__ == '__main__':
    main()
Code:
mrmidi@dorn:~ $ sudo flashrom -p linux_spi:dev=/dev/spidev0.0 -w 226-padded-150.rom
flashrom unknown on Linux 6.12.25+rpt-rpi-v8 (aarch64)
flashrom is free software, get the source code at https://flashrom.org
Using clock_gettime for delay loops (clk_id: 1, resolution: 1ns).
Using default 2000kHz clock. Use 'spispeed' parameter to override.
Found PMC flash chip "Pm25LD512(C)" (64 kB, SPI) on linux_spi.
This flash part has status UNTESTED for operations: WP
The test status of this chip may have been updated in the latest development
version of flashrom. If you are running the latest development version,
please email a report to flashrom@flashrom.org if any of the above operations
work correctly for you with this flash chip. Please include the flashrom log
file for all operations you tested (see the man page for details), and mention
which mainboard or programmer you tested in the subject line.
Thanks for your help!
Reading old flash chip contents... done.
Erasing and writing flash chip... Erase/write done.
Verifying flash... VERIFIED.
I've changed clock speeds in Graphiccelerator using QEMU for the rom.
It's Radeon 7000.
Code:
File:   backup.rom
METHOD: heur
BLOCK:  0x05EE
RefCLK: 27.00 MHz
Where is radeon_rom_final.py from?
Using QEMU Mac OS 9 emulation to edit the rom?
I think actually the latest were in macosx-ati-displays-4-5-7.dmg. Still could be found on AMD website here: https://www.amd.com/en/support/down...-7xxx-mac-series/radeon-7000-mac-edition.html
I couldn't mount the disk image in modern macOS. The installer "ATI Displays 4.5.7 Update.app" uses VISE X 2.0. I don't know if there's an installer file extractor for that.
The "ATI Displays 4.5.7 Update.app" let me install it on an Intel Mac virtual machine running Mac OS X 10.5.8.
Did you get a "ATI ROM Xtender" file version 1.2.7f2 June 20, 2005 2:07 PM ?
In the post you are quoting. Patching part didn't tested at all, so I would not try it in a first place. It's just dirty prototype to test some values. :) Also I don't sure RefCLK values are correct. I've tested it with some PC roms from TechPowerUp, clock speeds seems to be detected right. I just didn't found any modern tools to view this data, so I've made my for Radeon 7000 by briefly decompiling Graphiccellerator java app + included XML for offsets.
OS X Tiger, same one I've cloned to my G3 hdd later.
Exactly the same.
Oh, you made it yourself. Nice.
The fixed offsets in the Graphiccelerator.app's ROMDefs.xml file isn't going to work for some custom ROMs (ROMs that aren't just edited or patched) but I guess most ROMs are not custom.
The heuristic method doesn't work if the memory and core clocks are not the same.
The Mac ROMs will set a property in the device tree for the clocks so I guess you can verify if the correct value is obtained/changed by your script.
Actually, if you look for the code that sets the properties:
Code:
value_893_6978  encode-int " ATY,RefCLK" property
value_894_101d0 encode-int " ATY,MCLK"   property
value_895_101d0 encode-int " ATY,SCLK"   property
Then you can see what values are used to set the properties, and you can backtrack to where the values are initialized:
Code:
6978 value value_893_6978
101d0 value value_894_101d0
101d0 value value_895_101d0
But you have to check if the values are later modified:
Code:
2cad8 to value_894_101d0
2cad8 to value_895_101d0
I forgot that Graphiccelerator was Mac OS X.
  • radeon_rom_final.worksheet.zip
Reactions: mrmidi
Wow, looks useful.
Nah, I don't want to poke it around anymore. Radeon works stable more or the less. I've ordered new SOIC-8 chip with larger memory, maybe I'll re-solder it later to flash a full rom.
I'll better get back to what I've really needed G3 for - capturing FireWire packets to restore FireWire audio support for modern macOS :) It's open source btw.
What's open source - your radeon_rom_final.py script or something FireWire related?
The IEEE Std 1394-1995 and IEEE Std 1394-2008 specs are available for download but I don't know if that helps for audio.
FireWire related?
This. I wouldn't be advertising it in this thread, very off-topic. I need to find a better place to talk about it here :)
Generally not so much, it's very unrelated to audio itself but contains a good grasp of what this interface is and how it works. Most of Audio related stuff described in IEC 61883-6 and 1394 Trade Association specifications. But I think I have (almost) everything I need. There is some specifications that was never published officially and was available only for 1394 TA members.
Apple's old documentation on 'NDRV's said you could just place a file on the disk( assuming in the Extensions folder ) and it did not need a resource fork, but I was never able to get that to work.
Maybe a .pef would load from the Extensions folder, I never tried. I think in this case we have to load it as the driver,AAPL,MacOS,PowerPC property before we hand off control to the nanokernel otherwise it won't be able to draw the screen.
Of course we'll need to open the screen first:
Code:
" pci/@f/@0/@0" 2dup find-device open-dev to my-self
This worked, and I was able to draw the rectangle.
but this was a default catch:
Code:
" pci/@f/@0/@0" 2dup find-device open-dev . dup to my-self
Testing on the GF6600.
The should be:
Code:
" pci/@f/@0/@0" 2dup find-device open-dev dup . to my-self
Did you have any luck, I have an old M-Box Pro FW but can't really be used past Mojave I think?
Reactions: ediflorianus
