I tried the hard reset method and it seemed to help... no drain overnight last night. Curious to see if that trend continues.
yes. so last night i took them off, put them in the case. but they still showed battery percentage in my battery widget on iPhone. this is the bug. so i took them out again, and put them back in, they disappeared from the widget, disconnecting properly, hopefully when I check tonight they will have drained a couple percent. always check your device to make sure it disconnected. the case seems finicky.12+ hours after using the APMs... they still show up on my devices bluetooth with charge%. Why are they still connectedand is this causing battery drain?
the software version is the same right? this is the first time ever I've seen only 3% drainYea same i dont know if something changed but last night to today dropped from only 100 to 97
im thinking the hard reset is working bc it is actually disconnecting as it should vs the bug where it still stays connected. i don't think the reset is doing anything special or fixing a hidden bug.I tried the hard reset method and it seemed to help... no drain overnight last night. Curious to see if that trend continues.
I mean it was re-paired to all of my devices as soon as the hard-reset was complete, so therefore the only factor that changed was the process of resetting it. It was paired to my devices overnight as usual last night.im thinking the hard reset is working bc it is actually disconnecting as it should vs the bug where it still stays connected. i don't think the reset is doing anything special or fixing a hidden bug.
i don't mean paired i mean actually connected. like actively it says connected in bluetooth settings and shows up in the airplay tile and in the battery widget while being in the case. that's the bugI mean it was re-paired to all of my devices as soon as the hard-reset was complete, so therefore the only factor that changed was the process of resetting it. It was paired to my devices overnight as usual last night.
I was at 31 percents left them one day. Next day It was 1% and when I listened music, It turned off immediately.Last night I went to bed and left them at 1%. 7 hours later they are still at 1% and connect to my iPhone.
As I mentioned earlier, I’m pretty sure it’s probably not a draining issue. They just read the battery levels incorrectly. They probably still drain a little, but on top of that they show lower battery levels than they actually are.
so you woulda lost 12% by bed time again. seems in line with the ~10% per 24 hours. seems like the actual drain should be the 3% that me & someone else have seen. that seems more like what apple would have implemented. let's keep our eyes peeled for a software version update & making sure it's disconnected when put in the caseGood morning.
Yesterday I went to bed with 31% of battery, and I did the factory reset before putting them in the case and after 8 hours, it lost 6% reaching 25% on the morning.
If you’re right (plausible), then technically, the hard reset is fixing the bug where they aren’t disconnecting 🙂im thinking the hard reset is working bc it is actually disconnecting as it should vs the bug where it still stays connected. i don't think the reset is doing anything special or fixing a hidden bug.
the headphones have proved they are capable of draining only 1-3% in 24+ hours. so anything more would show something went wrong. idk if turning off automatic head detection might fix it. and turning off the automatic switching. just turn everything off for a week. if no drain then it may show the culprit. ill try that this week.If you’re right (plausible), then technically, the hard reset is fixing the bug where they aren’t disconnecting 🙂
So it may just be that the APM aren’t going into ultra low power mode?
Usually, when they hit 1%, they keep playing for another hour in my case.I was at 31 percents left them one day. Next day It was 1% and when I listened music, It turned off immediately.
So far I understand you got them a week ago. For the first week you had no problem with the battery, and I asume this is the first time you fully charged and after 10 hours resting inside the case you saw that it went from 100% to 58% . Am I right?got mine less than a week, charged overnight the left in the bra for 10hrs, battery is 58% left ... booo!!! tried reset and will observe how it goes
the simple fix is: they disconnect after 5 minutes. they turn off after 1-2 hours. not this 72 hour 18 hour nonsense. case or no case.
Apple states the reason for the 72 hours before ultra low power mode is “Find My.”That is unbelievably awful for a pair of wireless headphones. A proper pair will lose 0 percent.
Which is absurd. None losses at 550usd device and doesn’t notice it right away. Especially for a device that is going to be most of the time in you house oR hangin from your neck when using it. And if someone stole it or find it , it’s most likely that that person would keep it , cause you can’t protect by password this device, nor block it nor send a message like the iPhone, which means anyone can use it.Apple states the reason for the 72 hours before ultra low power mode is “Find My.”
very much correct! and that time i noticed while in the sleeve it was still connected to my iphone. After the reset 3% drop overnight. Now im happy.So far I understand you got them a week ago. For the first week you had no problem with the battery, and I asume this is the first time you fully charged and after 10 hours resting inside the case you saw that it went from 100% to 58% . Am I right?
check what firmware is in your AirPods Max. I got the same behavior after one week. And I think is when the headphone are updating that they get their first battery drain.
After that we ‘suspect’ that it is related to multiple device usage with.
That 3% drain overnight only happens is you kept then inside the case with 100% baterry.very much correct! and that time i noticed while in the sleeve it was still connected to my iphone. After the reset 3% drop overnight. Now im happy.
Yea why is thatThat 3% drain overnight only happens is you kept then inside the case with 100% baterry.
But if you keep it with, for example, 95% of battery, your battery is going to be 85% , draining around 10% :/
