The issue is that the first AirPods Pro had almost no standby case drain for me compared to these AirPods Pro 2. It’s a huge negative difference.
Has anyone managed to resolve this yet?
So, now I got my APP2 back I'm back to level sucking. I got them with 90% battery level yesterday, listened for 30 minutes to music and 16 hours later the case is at 68%Mind-boggling: sent my AirPods Pro 2 to Apple for repair. Get it back with the message that they couldn't reproduce the issue. So far, nothing new (A certified service provider concluded the same earlier). Nevertheless... the package with the APP2 was delivered to a depot one day before the weekend. Because of some personal reasons I only could pick it up after the weekend. I opened the package, connected the APP2 to my phone and voila, the case was at 90%! So a loss of max. 10% in 3 days.
So, apparently the drain is caused by the connection to the phone, the 'find my service' or any other service that is polling the case. Away from the phone, and not connected to a find my service it seems to have the best battery life ever... (BTW the certified service provider, that diagnosed my AirPods the first time, said that they did a "field test" by leaving my case unused for a couple of days and they measured 0 battery loss)
Your case would be failing if it wasn’t draining constantly. It’s just how they’re designed to work, and how every single AirPods iteration has functioned. The thing I noticed with the latest firmware is that now the case reads 100 percent a lot longer than before, which is consistent with how iPhones, iPads, macs etc behave.So after a couple of resets and unpairs, my AirPods case actually behaved normally for half a day. Did not lose any charge in standby and could easily charge the airpods from 98% back up without losing any case % below 100.
Unfortunately issue has returned again and now draining in standby and 1% of AirPods charge = 1% of case drain.
This leads me to believe there is some universal firmware issue with the second gen pro’s. Hope they can patch it.
Please stop with these absurd replies. Given the countless complaints all over the internet it is by far clear that there's something wrong with the battery life of a lot of AirPods Pro 2.Your case would be failing if it wasn’t draining constantly. It’s just how they’re designed to work, and how every single AirPods iteration has functioned. The thing I noticed with the latest firmware is that now the case reads 100 percent a lot longer than before, which is consistent with how iPhones, iPads, macs etc behave.
That’s complete BS. The AP2 are behaving identically to all the AirPods in the past. And if you look back to the release of every other set of Airpods, there’s always people complaining about this same issue.Read before responding next time.
I have the original pro’s as a comparison and the second gen pros case behaviour is bugged.
Thanks. Bang goes that theory.For me it happens both when I’m at home with my Mac and when I’m out without it so for me it makes no difference
Completely normal behavior to drop that much battery overnight.Just a possibility: I too have suffered significant battery drain using AirPod Pro 2. Mainly noticed the case losing battery power overnight (3-6%). I also have an iMac (in addition to my iPad and iPhone), which I usually leave on standby overnight. A few times recently I've been shutting my iMac down at night and I don't know if it's coincidence or just hope, but my AirPods don't seem to lose power when my iMac is shut down.
Does anyone else who has experienced this problem have a Mac that they're leaving on standby overnight, or am I just seeing something that isn't there?
Interesting! How did you unpair from any device ?I was experimenting the usual 1% per hour like many of the users.
Then I tried the method described some post before with an add on: I unpaired my APP2 from ANY device they where paired to: MacBook, iPhone 12, iPhone 14 PM.
Then pair again and charge until the case reached 100%.
Well, the case is still at 100% from 72h 😳 weird.
I’ve never used the AirPods since the charge.
Today i’ll try to use the airpods, then i’ll keep monitored the case.
EDIT
I tried the buds for 20 minutes. The case went immediatly to 96% after i put the buds in, then it settled to 91% after the buds charge was completed. Let see if it starts dropping 1% per hour as before.
But how? First unpaired it via the bluetooth menu on your iPhone and next on the site(?) iCloud.com?From blueetooh + icloud.com
