We should find out soon when accessory manufacturers like Anker, Aukey, Baseis, etc. start manufacturing charges and cables that are compliant with the Apple MFi specifications.
Oh sure they will they’re gonna want to make money and don’t forget belkin Good griefWe should find out soon when accessory manufacturers like Anker, Aukey, Baseis, etc. start manufacturing charges and cables that are compliant with the Apple MFi specifications.
Nope as long as I have disposable income, I’ll decide if I want to upgrade or not.Easy fix, don’t buy new gadgets for a little.
I have had several USB-C Ports break on devices (including two iPad Pros). I've never had a lightning port break on me. I've ended up with it a little loose and have had cables break, but not the port itself. Much much more expensive to replace a port on a device than just get a new cable.
I agree with you completely.
But having to argue that anything better than USB 2.0 is just for "professional needs" highlights how ridiculous this discussion is.
USB-C is the standard that you get in all new consumer tech and is dirt cheap to implement in hardware, even the high-quality and high-speed ports like the ones you see in MacBooks and iPads.
This positioning as anything better than Lightning as frivolous, weird, not trustworthy, "flimsy" or unnecessary just proves how deep the Apple propaganda goes.
And Apple fans wonder where the "iSheep" stereo type comes from. Lol.
Who in their right mind wants to spend $999+ on a smartphone with I/O that's 10+ years old?
Lightning was great in 2012.
But now, 10 years later, it's just time to move on to something faster, better, and cross-compatible with every other consumer technology product made in the last 5-10 years, "professional" needs or not.
Ok then.I think wireless charging is useless, I've never used it.
It‘s like the removal of the 30 pin port and the 3.5mm port all over again, life goes on.I guarantee you more users care about the connector standard than about the CPU process node.
Apart from that, Samsung already shipped 3 nm processors last year (though not in smartphones): https://www.phonearena.com/news/samsung-first-to-ship-3nm-gaa-chips_id141505
The part that's most likely to be damaged on both types of connectors is the plug on the cable - not the jack on the device.The part that can be damaged is on the cable, not inside phone.
My CarPlay is wired only and I charge on a slow MagSafe stand at night.Meh.... I don't even remember the last time I used a cable with my iPhone tbh... I have wireless charging in my car, and a magsafe duo on my night table..... And with icloud I don't really transfer any data. I think I'm ready for a portless phone.
I just bought a pack of 3 USB-A to C adapters for my car. Without them I wouldn’t be able to use the newer Apple cables. Even if I don’t upgrade, I’ll still be able to use the USB-C to lightning cables with my 14PM.Hopefully it will come with a C to C cable I don’t want to use the one for my iPad Pro. I need to get a A to C cable for my car stereo those still use USB A
Probably best that you don’t upgrade then 🙂👍And, anecdotally, in the handful of years we've had C cables in our house, including purchasing Anker ones to replace the cheap Amazon ones, they fail about 2:1 versus Lightning cables. Generally at the connector.
Purchasing new cables and tossing old ones that cannot be used any longer does not positively impact the environment. You're not going to cut down on how many cables you go through and statistically might use more of them because the connector is easier to damage versus the Lightning connector. I've only had 2 Lightning connectors fail since going to the second gen and both were because the cable fell in the floor and got stomped by one of my kids.
You just put the plug in the jack. Orientation doesn't matter. USB C is virtually no different to use than Lightning. I think it's ironic to see people holding up the Lightning plug on their charging cable and claiming how it's so much better than the plug that's already on the other end of the same cable.USB C ports are a pain in the ass to use. I guess I’ll have to get a magnetic charging platform for my iPhone, Apple Watch & AirPo Pro. I will miss the lightening connectors, I guess I’ll have to take them all in to Apple for recycling. 🙁
USB ports don’t break.I have had several USB-C Ports break on devices (including two iPad Pros). I've never had a lightning port break on me. I've ended up with it a little loose and have had cables break, but not the port itself. Much much more expensive to replace a port on a device than just get a new cable.
No, but Apple specifically said they would not change the lightning port in the next 10 years in response to MFI accessory makers (and consumers) being reluctant to invest in a technology that was going to be deprecated quickly after making sizable investments in the iPod 30-pin connector. Could you imagine the uproar if Apple had introduced lightning and then dumped it in the very next models when USB-C came out?Steve said OS X setup Apple for the next 20 years starting back around 2001. Doesn't mean they're going to get rid of OS X anytime soon.
🔥🔥🔥🔥🔥I agree with you completely.
Not exactly true. While I wouldn't characterize it as "so much better", Lightning allows for greater degrees off-axis insertion in all directions as the tab is self-guiding into the port. UBS-C requires nearly perpendicular insertion with the port friction against the plug beginning about 1.3mm in the port before the lightning. This wiggle room is why it is much easier to blindly plug in a lightning connector than USB-C. The plug on the other end of the cable is a non-issue as it is less frequently unplugged.You just put the plug in the jack. Orientation doesn't matter. USB C is virtually no different to use than Lightning. I think it's ironic to see people holding up the Lightning plug on their charging cable and claiming how it's so much better than the plug that's already on the other end of the same cable.
No A series SOC has supported Thunderbolt to date. The iPad Air and iPad Pro support Thunderbolt, but have a M series SOC. The iPad mini has an A series SOC and only supports USB 3.1 Gen 1 over the Type-C cable.I'm not saying they will just market its Thunderbolt, they will make it full fledged Thunderbolt, with faster than USB 3.0 speeds, so they don't ever have to mention USB speeds.
