OP posited that in forcing Apple to change from lightening to usb c the EU was causing damage to the environment.Not sure what the argument is about durability. There is nothing to suggest USB-C spec is technically stronger than lightning. It's up to the manufacturer and designer to use whatever materials to protect the cable.
If you're talking about Apple cables vs third party, third party uses PVC materials that are bad for environment (possibly toxic to humans) but are more durable and cheaper. Apple avoids that material.
Switching to USB-C means Apple will include a USB-C cable that's roughly the same durability assuming same materials are used.
My argument was that given lightening cables break all the time anyway having to buy different replacement cables makes hardly any difference to the environment.
I continued to suggest that in my experience thus far usb C cables have been more durable (I’ve not had one break yet), and if that holds out my impact on the environment might ultimately be slightly reduced.
